Vararam
Old 12-14-2022, 10:48 PM   #1
lanejesse85
Drives: 2013 Chevrolet Camaro 2SS 1LE
DRL/Fog Lamp Bulb issue
Hello all, thank you for allowing me to become a member to the forum. I've heard this is the #1 place for all things 5th gen.
Anyways, just bought my 13' 1LE and I'm trying to get everything to 100% and one thing I have to work on is getting my exterior lighting fixed. When I got the car all the marker lamps were inoperative and so were the DRL/Fog Lamps (which on is is it? I have heard both, my vehicle is equipped with RPO T4F, I think that determines which it is). I was able to get the marker lamps working 3 of them just needed bulbs while the left front needed a new pigtail and a bulb. Now I have moved on to my DRL/Fogs, and I am having troubles finding the right bulb. I'm going through the dealer and the first set they gave me was totally wrong, the second set the bulbs fit into the housing but the socket connector was wrong and the connector coming from the harness would not engage. I've tried going back in MY, forward in MY and even trying base/RS trims and the ZL1 trim and I cannot seem to find the correct bulb. Can any of you provide me with a part number? Or any help at all on finding the right bulb? This seems way more difficult than it should be.
Thanks again for the admission and thanks in advance on any help or insight.
lanejesse85 is offline   Reply With Quote
Old 12-15-2022, 09:04 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Not sure how it works for a 1LE but, the RS package has DRL and non-RS has fog lights.
Old 12-15-2022, 12:03 PM   #3
1LeSS
1LeSS's Avatar
Drives: 2013 2SS/RS VR 1LE
Late 2012 and early 2013 GM used a different bulb in the fog/drl light. Instead of the P13W they used PSX26W.
Hope this helps
BC Racing coil-overs, 32ml rear sway bar, Solid cradle bushing kit, Steel jacket radius rod bushes, JPSS caster bolt, Bo White TB, Granitelli HP coils, Apex Catchcan, Vortech V7 Ysi Supercharger, LSX B-15 engine, custom spec cam, and other stuff.
1LeSS is offline   Reply With Quote
