11-14-2022, 06:09 PM | #1 |
Drives: Chevy Camaro ZL-1 Join Date: Feb 2020
Z28 Wheels and Tires on 2013 ZL1
Just picked up a Mint set of OEM Z28 wheels and tires 19 inches. Tires are P zero Trofeo-R. 305/30/19. Thinking of putting them on my 2013 Zl1. Any potential issues I may run into?
11-14-2022, 08:59 PM | #2 |
19’s
Running 6th Gen ZLE on my 2010 305’s front and 325’s in the rear on 19x11 an 12’s think I need a 3mm spacer for the rear just to give me a little breathing but nothing rubs except for the parking brake cable need to tie it back possibly.
Orange Krush II
11-15-2022, 01:21 AM | #3 |
Give speed a chance
You might get tired of people coming up to you and telling you how bad ass your car looks. Good score!
11-16-2022, 12:09 AM | #4 |
Drives: Camaro SS Join Date: Jan 2015
I don't have a zl1 but I have been running the oem 5th gen Z/28 wheels on my
ss for years. |
11-16-2022, 07:08 AM | #5 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Hey my friend, did you need spacers for the rear and how much do you think they stick out if at all ?thank you
11-16-2022, 03:51 PM | #6 |
11-16-2022, 10:33 PM | #7 |
Its lowered on coil overs. I did have to run a camber plate setup in the front though to accommodate 305s.
11-19-2022, 09:31 AM | #8 |
Drives: 2013 ZL1 Camaro Join Date: Feb 2018
Great pic. Brings back a flood of memories.
11-22-2022, 12:14 PM | #9 |
Drives: 2013 chevy camaro ZL1 Join Date: Aug 2013
Tires
It appears Goodyear has discontinued the Eagle F1 for my 2013 ZL1. Any suggestions for replacements? Traction is key, not mileage. Thanks!
11-23-2022, 01:29 PM | #10 |
Can't go wrong with Michelin PS4s. Have them on my stock ZL1 rims and they are great. Much better traction then the BFG.
12-11-2022, 08:05 PM | #11 |
I also run them on a 13 for years, car sits low enough to rub headers hard. They stick out a little too. I put the Z28 flares too to compensate for this, car looks bad ass even with 20s too.
JRE 750 HP package
Rag Top Rob |
