Old 10-31-2022, 01:53 PM   #1
GlassMan45
Drives: 2023 VOM Camaro 2SS Coupe
Underbody materials
Hello everyone. I am new to these forums and tried to search for this answer but could not find what I was looking for...I may just not be searching properly.
Anyways, what materials are used for the underbody panels? Is it a composite material that is resistant to corrosion from salt and water, or is it a metal that is susceptible to corrosion?
If the latter type of material is used, is there a coating or cover that people like to apply to the panels to help resist corrosion?
Thanks in advance for the help!
GlassMan45 is offline   Reply With Quote
Old 10-31-2022, 02:04 PM   #2
tlr3715
Drives: 2002 Z28, 2023 1LT RS Redline
According to the manual underbody components are coated with an anti corrosion material. They recommend spraying with clean water every six months to remove corrosive elements but state not to use cleaners as that could remove the anti corrosion coating. We’ll see how well it works.
I know Ford is awful with this as my 2017 mustang rusted quite a lot on the underside. There was no mention of anti corrosion in that manual if that says something.
tlr3715 is offline   Reply With Quote
Old 10-31-2022, 04:41 PM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Maybe the video will help
nancygrl is offline   Reply With Quote
Old 10-31-2022, 04:49 PM   #4
LeonardS
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS
That’s the Gen 5 that was built in Canada. Probably a little different process than the Gen 6 built in Lansing. It is an interesting video!
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles.
99 SS Vert, Hugger Orange, A4, 806 miles
94 Z28, Black, M6, 595 miles
92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
LeonardS is offline   Reply With Quote
Old 10-31-2022, 05:32 PM   #5
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
There is a similar, 44-minute video about the 6th gen from 2017, but I don't recall it discussing the underbody or coatings specifically. The video itself is a concatenated set of episodes in the "Supercar, Superbuild" series, and had been viewable on youtube until a 2 or 3 years ago, someone must have complained and it got pulled.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 10-31-2022, 06:51 PM   #6
pzoom
pzoom's Avatar
Drives: 2021 SS 1LE SHOCK
Car companies have been zinc dipping (galvanize) for years. I know they used to wax dip truck frames. They also squeeze sealant on certain areas.
However unless you are driving a Delorean, any nicks, scratches, and trapped corrosive materials will cause rust. Best prevention is to do regular under body washes and paint any deep nicks.
pzoom is offline   Reply With Quote
Old 10-31-2022, 07:09 PM   #7
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Or, take the Joshinator99 method: never drive it in rain, snow, salt or anything other than a gloriously nice day. That said, I really don’t drive my car enough.
Old 10-31-2022, 09:41 PM   #8
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
all cars rust underneath imho. you want it to stay nice avoid winter driving.
Camaro fanboy is offline   Reply With Quote
Old 11-01-2022, 05:38 PM   #9
GlassMan45
Thanks for the information everyone. I understand it would be ideal to not drive it in winter/bad weather to avoid the salt, but my situation does not really allow for a second car right now (mostly due to space).
For some context, I am deciding between a camaro and a corvette and read that the corvette under body has composite body panels that are resistant to corrosion so I figured I would find out if the camaro under body was similar.
P.S. I know many of you are probably cringing at the thought of either a camaro or corvette being driven in snow, but I would rather have a sports car and drive it year round than not at all.
Old 11-01-2022, 06:41 PM   #10
arpad_m
arpad_m's Avatar
No cringe whatsoever, I lived in northern NJ with 4 months of winter each year, and many drove their Camaros in rougher weather, too. Since this is my forever Camaro, I decided not to do that, but the wife has a 2016 Traverse (so another GM vehicle) as a daily, and the salt and brine did a number on its underbody.
It's definitely not as bad as a car from the 90s or early 2000s, the underbody is protected, but wherever the coating got damaged from road debris, rust has started on the frame.
735 rwhp | 665 rwtq
Old 11-02-2022, 06:18 AM   #11
NashZL1
Drives: 2022 Camaro ZL1
If you're concerned about the underside, you might look into getting an Underwasher. I use mine after one of our cars has been through snow or mud, and for at home use, it's pretty effective.
https://www.theunderwasher.com/
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2016 Hyundai Equus Ultimate
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
