Old 10-20-2022, 08:42 AM   #1
LSA
Drives: Fast
Solution for Tire Slipping on Wheel
After a single session, my 3Rs rotated ~90 degrees on the stock OE wheel. This makes for some really sweet vibrations on the straight >140.
Anyone found a solution?
A mechanic friend suggested xtra-Seal Bead Sealer. Anyone tried this or a similar bead sealant?
LSA is offline   Reply With Quote
Old 10-20-2022, 10:23 AM   #2
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
I've had tires slip after being freshly mounted, usually because they use too much lube. A month later it seems like the lube dries up and they hold fine. I don't think I'd try to put any sealant or other material on the bead. You want it dry.
rotis is offline   Reply With Quote
Old 10-20-2022, 11:25 AM   #3
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Swap the tires from one side to the other. I've done this and the tires will start to rotate back the other way. Plus you'll help keep the tire wear more even. While not a proactive solution, it may lessen the effects. I've done this in the past and it works but there is no guarantee they'll move again or even enough. I've found the tire that moves the most is usually the least loaded tire. For example, at my track, Pitt Race, it is a right corner dominant track with the heaviest braking occurring mostly at right turns. My RR tire was the one that moved the most.
My tire guys were very responsive to trying minimal lube or even something else like Windex. But this can make setting the bead difficult. I think the minimal lube helped but I really did not find the previous movements create any vibrations. I think tire choice matters as some manufacturers have a better hold on quality control than others. More often than not, my wheel weights usually ended up in the same areas on the wheel. That points to the wheel being the dominant factor on imbalance. I see you are using 3Rs and I have used them also and had movement, so my thoughts on the tire choice may not be accurate.
Once I got my freshly mounted tires back, I would wash them and remove as much of the excess lube from near the bead. I also let them sit out in the direct sun to help dry out the lube.
Your friend's suggestion wouldn't hurt. If that's the same black stuff they use on old, corroded aluminum wheels to help the seal, that might help.
cdb95z28 is offline   Reply With Quote
Old 10-20-2022, 11:41 AM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
new wheels with a bead slip grip made into them
Old 10-20-2022, 01:03 PM   #5
rotis
rotis's Avatar
I'll add that I have knurled bead seats on all my track wheels, but I've still had freshly mounted tires slip. The knurled bead seats probably help, but I think excess/fresh lube is the most likely culprit.
Old 10-20-2022, 01:09 PM   #6
LSA
Drives: Fast
My understanding is the OE ZL1 1LE 19's have a knurled bead.
The tires were mounted 2 months prior to being used, so the lube wasn't fresh. But there was a lot of it. I can talk to my installer about using less.
I have had the same result, however, with 3 different tire installers. Maybe they're all using too much lube. Who knows.
Appreciate the responses.
Old 10-20-2022, 01:40 PM   #7
cdb95z28
cdb95z28's Avatar
I don't think the ZLE wheels are knurled. The Gen5 Z/28 wheels were.
Old 10-20-2022, 03:31 PM   #8
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
This is enlightening for me as I had never heard of this outside of drag racing.
2018 ZL1 1LE - Red Hot, Nav, PDR
ZL1 1LE is offline   Reply With Quote
Old 10-20-2022, 04:14 PM   #9
HD_ZLE
HD_ZLE's Avatar
Drives: 2020 ZLE
This also happens on my knurled bead wheels. Using less tire lube and letting it dry up some helped a bit, but not fully. Just ignore it and send it
2020 ZLE A10
Rotofab, SPL suspension goods, Cobalt XR1 pads, Apex wheels
HD_ZLE is offline   Reply With Quote
Old 10-20-2022, 09:17 PM   #10
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
It can be kinda uncomfortable to send it to and beyond 130-140 mph when wheel weights move around relative to the tire and you get nasty vibrations.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 10-21-2022, 07:03 AM   #11
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Can we track on beadlocks?
That1guy_tim is offline   Reply With Quote
Old 10-21-2022, 07:39 AM   #12
travislambert
travislambert's Avatar
Drives: '17 ZL1
I used knurled BC Forged wheels with 3R tires and all 4 tires rotate on the wheel. I use a minimal amount of the GM recommended Hunter brand tire lube and found it makes little difference.
The best solution I've found is just to minimize the use of weights. If you aline the white dots on the tire opposite the valve stem, the weight required to balance a 3R should be minimal. My car is dedicated for track use, so unless it needs more than 2 ozs, I don't even bother with weights. I've never noticed any vibration with this approach.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 10-21-2022, 07:54 AM   #13
HD_ZLE
HD_ZLE's Avatar
Drives: 2020 ZLE
Agree with this too. A lot of folks that run slicks/scrubs will balance a wheel without tire and just run it, or not balance anything at all. All the fun of something this fast and heavy
2020 ZLE A10
Old 10-23-2022, 05:24 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the factory 19" ZLE wheel is not knurled but the '14-'15 19" Z/28 wheel is knurled. My last two new 3Rs took .75 oz and 1.25 oz to balance so no big deal if you don't balance them. I balance mine myself so this is real data. Make sure you cover the adhesive wheel weights with the foil like racers tape and your weights will never fly off.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
