09-22-2022, 10:51 AM | #1 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Auxiliary fuel system Does yours leak ?
Hello
Good morning Who has had experience with the Auxilliary fuel system leaking ? I hear it is fairly common What was the remedy you implemented ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
09-22-2022, 11:30 AM | #2 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Are you referring to the DSX kit? I had a hell of a time when I first installed it leaking at the tank fitting. Just "working with it" and trying different combinations of tightness of the fitting helped... If mine ever shows any signs of leaking again, I'll either:
A) Go with an intank solution (expensive) or B) Try to use some kind of bulkhead type fitting that they normally use on fuel cells (cheaper), but not sure if the curved area of the tank where it's add will work. or C) Others have suggested going with the next size up fitting for the tank. Honestly in hindsight tapping the tank was a stupid idea. I had expected more meat to thread things into.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
09-22-2022, 11:38 AM | #3 | |
I just installed a few mods and got a bump in power. Still on stock LT1 fueling 40k miles Almost 20k boosted on Heartbeat kit pulley (single digit PSI) I think it's time to be satisfied with my power levels and just enjoy the car. In a few years I'll consider upgrading to a ZL1 or C7 Boost is most expensive when you get greedy
16 1SS M6 White
09-22-2022, 03:54 PM | #4 |
Someone here or on another thread today mentioned the danger associated with running less than 1/4 tank of fuel with DSX's low side fuel pump and Gen6's saddle style fuel tanks. I asked DSX about this and they said I shouldn't have a pressure problem unless the "low fuel light is on." Anyone know at what level the fuel light comes on?
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
09-22-2022, 04:14 PM | #5 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
09-22-2022, 04:31 PM | #6 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
The biggest problem I see with tapping the tank is running the tap in too far. I used a 9/16 drill bit - a little smaller than recommended. I ran the tap in a little ways and checked it. Kept doing that until I got the right depth. Oh yeah, DO NOT USE A WRENCH ON THE FITTING!!
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
09-22-2022, 05:53 PM | #7 | |
We installed the DSX a year ago. When the car was on the lift a few weeks ago, we noticed the tap had been leaking, so we cleaned the outside and added some additional sealant. It's a real touchy little connection.
'20 ZL1 1LE A10.
09-22-2022, 05:59 PM | #8 |
3 years
How many miles though ?
16 1SS M6 White
09-22-2022, 06:15 PM | #9 | |
Mine is solidly in place and I don't see why or how it would start leaking.
09-22-2022, 09:03 PM | #10 |
Cordes performance aux setup I believe uses a bulk head fitting for that reason.
2016 NFG 1SS A8
09-22-2022, 11:27 PM | #11 |
09-22-2022, 11:34 PM | #12 | |
Having FUN in the SUN...
I have the same concerns... Makes me worried that a small fender bender could knock it loose? This may push me to do an in-tank pump for this reason.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 770rwhp 815rwtq @E55 13.5psi |
09-23-2022, 02:07 AM | #13 |
Agreed and did in-tank for this reason. Having a tapping in a tank that is too thin to be tapped properly AND below the fuel level is more than I was comfortable with.
09-23-2022, 08:11 AM | #14 |
I just contacted them about it, and, yes, they do sell one, thx
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. Last edited by JSH; 09-23-2022 at 01:28 PM. |
