View Poll Results: How many track days out of your Hawk pads? | |||
5-7 | 2 | 28.57% | |
8-10 | 5 | 71.43% | |
11+ | 0 | 0% | |
Voters: 7. You may not vote on this poll |
Thread Tools |
08-30-2022, 09:37 PM | #1 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
How many track days did you get out of your Hawk pads?
So I am doing my 7th track days on Hawk DTC 60s. I think I have a few more in them, but I wanted to see how many days you guys got out of a set of yours.
08-31-2022, 07:34 AM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Crap, that sounds pretty good. I get 4 (nasa days about 5.5 hours) out of my carbotech xp12s. Put some xp20s up front this time to see how they do but only got 2 days in them so far.
Also hours would be a better gague than days. |
08-31-2022, 08:07 AM | #3 |
11... ELEVEN?!?
What in the hell compound are you running that you can get 11 track days out of your pads? Summary, I believe your survey choices to be inaccurate. ...but that's just me.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
08-31-2022, 08:41 AM | #4 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
I have tried xps and cobalts. They are super easy to burn through. dTcs on the other hand last much longer. Like 2x. Probably harder on the rotors
08-31-2022, 08:42 AM | #5 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
The only time that's a problem is if your brake pistons are not moving in and out normally and in that case typically the pads will be dragging against the rotors causing some unnecessary wear. I will also say that yur driving style makes a HUGE difference in your pad life. I try to be OFF the brakes as much as possible LOL
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
08-31-2022, 11:08 AM | #6 | |
I don’t expect too many in the 11+ Category, but we shall see. Already a few n 8-10. I will get at least 9 out of mine I think. Last edited by 5.M0NSTER; 08-31-2022 at 11:26 AM. |
08-31-2022, 11:10 AM | #7 |
i put my first set on last year around may and did around 7-8 days before i replaced them
just replaced with them with same pads and added the girodisc rings for the front and new oem rear rotors
08-31-2022, 11:13 AM | #8 | |
08-31-2022, 11:51 AM | #9 | |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
08-31-2022, 07:04 PM | #10 |
Depends on a lot of things like: Are you using slotted rotors. When are you changing them. Some people run then down very low, while other replace them when there is .080" or more left. What tracks are you running, high speed, medium speed, low speed. How many laps per day, etc.
08-31-2022, 09:04 PM | #11 |
about 5 days at VIR is typical for DTC 70/60
08-31-2022, 09:16 PM | #12 |
Please vote guys, not easy to tell unless you push those buttons to select the options.
09-01-2022, 02:08 AM | #13 |
Drives: 2017 SS 1LE Join Date: Mar 2016
I need a less than 5 option lol
IG: @NC_M1SS1LE
09-01-2022, 08:45 AM | #14 |
