08-18-2022, 06:45 PM | #1 |
Drives: 2019 ZL1 Join Date: Jan 2020
Brake Job Pricing
Got a couple of prices for a brake job from the mechanic I have used for years and trust
4-wheel pads and rotors 2019 ZL1 aftermarket parts $900 OE parts $3,000 What am I missing here? The mechanic said it's the most expensive brakes he has ever quoted. Thanks for any input |
08-18-2022, 07:04 PM | #2 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Rockauto.com
08-18-2022, 07:13 PM | #3 |
What's the quote breakdown? What aftermarket parts?
08-18-2022, 07:26 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Why are you replacing the rotors? Are they damaged?
08-18-2022, 07:41 PM | #5 |
Drives: 2010 camaro Join Date: Dec 2017
Sounds about right for a full replacement. If he's a credible mecahnic, pay him for the job. or you can can get a sloppy mechanic to do it fro a 100 or 200 bucks cheaper and mess up with cosmetics on the car... who knows. If you trust him, do it!
08-18-2022, 08:34 PM | #6 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Rock auto has OEM rotors (F/R) and OEM pads (F/R) for $1,400 total.
Either your mechanic doesn't know where to shop for parts or he was hoping to get a few bucks from you. gmpartsdirect.com is also a good place for OEM hardware.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
08-19-2022, 12:24 AM | #7 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Super easy to replace yourself, that price is a shock to me as I've done an entire refresh on a custom Wilwood, 14 inch 2 piece rotor, 6 piston calipers (front), and 13 inch 2 piece rotor, 4 piston (rear) + pads and new wilwood fluid for slightly less if not the same.
Damn Brembo shit is expensive!!!! |
08-19-2022, 06:57 AM | #8 |
$3000 sounds about right if he's going to a stealership parts dept.
08-19-2022, 08:01 AM | #9 |
08-19-2022, 08:03 AM | #10 |
08-19-2022, 08:13 AM | #11 |
Stealer finally called me back
My Mechanic was not joking. List on the rotors $828 each Stealership quoted $2,510 for just the fronts |
08-19-2022, 08:19 AM | #12 | |
I have a local shop that I use frequently and I always tip the mechanics, buy beer, breakfast etc. When I need work done on the fly they get me sorted quickly and don't beat me over the head. Stay away from dealers unless you're doing warranty work. For consumables, any decent shop can get you sorted. |
08-19-2022, 08:21 AM | #13 | |
Get a local mom and pop shop around the way to change your brakes. Unless you're bleeding them, I've seen homeless guys get the job done to make a quick buck. Literally. |
08-19-2022, 09:02 AM | #14 | |
I rarely use a dealer for anything other than warranty work. Don't want to beat up on him, but if I can get all the OE parts for around $1,400 from Rock. It is probably worth my time to do it myself. |
