08-01-2022, 11:18 AM | #1 |
Drives: 17 SW 1LE Join Date: Jun 2017
Rear hub bearing bolt failure
Posting this in case it helps someone else.
The mounting bolts for the rear hub bearing backed themselves out while I was on track this weekend. Factory installed, never been touched. Under lateral load it felt fine, but driving straight it would wander. It almost felt like being hit by a gust of cross wind. Listen to you car on track, it might try to tell you something important. Dont ignore it. |
08-01-2022, 04:07 PM | #2 |
Yeah, but it tram lines so bad on the road (especially with SC3s)
08-01-2022, 09:47 PM | #3 | |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Known issues with the earlier cars. But yes, I agree feel the car it usually tells u something is up before it goes all the way out. |
08-01-2022, 09:48 PM | #4 | |
If it trams on the road, your tires are shot or your alignment is messed up. These are regarded as being very good in regards to not tram lining even in 1LE form. It's rare that mine does and only when the road has visible nasty ruts. |
08-01-2022, 11:04 PM | #5 |
Naw, the SC3s tramline bad. The PS4S not nearly so bad.
08-02-2022, 10:07 AM | #6 |
What is “tram lining”?
08-02-2022, 10:41 AM | #7 |
Drives: 21 Gladiator Mojave Join Date: Apr 2022
08-03-2022, 10:54 AM | #8 |
08-05-2022, 01:06 PM | #9 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Wow, the service manual says to use red thread locker on them when reusing them while replacing the rear hub. Maybe the factory didn't torque them fully on your car or forgot the thread locker? Were the bolts still tight on the other 3 corners?
08-25-2022, 01:16 PM | #10 | |
08-25-2022, 02:06 PM | #11 |
Drives: 2017 HBM Camaro SS 1LE Camaro Join Date: May 2013
Any chance you have a picture you could share? I have a 2017 SS 1LE as well and noticed that after I changed my rear control arms and toe links (SPL) I seemed to get more rear tram-lining. It could be because of the spherical bushings and/or more negative rear camber, but sounds similar to this. Probably a good idea for me to check these regardless. I haven’t noticed any issues on track, however. Is it an issue on the front hubs as well?
08-25-2022, 08:05 PM | #12 |
they are easy to see but you must release the lower control arm and toe arm to gain access to all three bolts. You must also remove the large 36mm nut and push the axle back. The three bolts are nothing special and are in a trianglar configuration.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold) '15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold) '12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold) Last edited by Stephen12ZL1; 08-26-2022 at 12:16 PM. |
09-01-2022, 09:17 AM | #13 |
I was able to gain access just by removing the axle nut and using a mini sledge to knock the axle back some. No control arm removal was required.
09-10-2022, 09:02 PM | #14 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Any pictures of this?
