06-06-2022, 09:55 PM | #1 |
Drives: 2008 z06 Join Date: Feb 2018
WTB zl1 go fast parts
Got a 2013 zl1 bone stock looking for the following
Headers or catless down pipe Cold air intake that will work with stock TB Injectors 850cc or bigger DSX flex fuel sensor DSX aux pump or a BAP ATI lower balancer overdrive Grip tech upper pulley Heat exchanger and tank and pump |
06-07-2022, 05:20 AM | #2 |
i have a 5" jlt intake and 90mm throttle body. pm me if interested.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
06-07-2022, 09:49 AM | #3 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Keep your stock parts for smog unless you plan on non-op
You'll thank me later.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
06-07-2022, 11:12 AM | #4 |
