Old 05-19-2022, 05:41 PM   #1
Slouden28
Drives: 2017 Chevy Camaro 1ss
Starter ground wire
I just finished my build and drove about 10 miles and the car died… found the starter ground wire was being cut into on the starter heat shield and it looked like it was trying to weld itself to the shield . I pulled the wire away from it checked all the fuses.. I can here the fuel pump kick on and the heater control light up but nothing else works and the gauges don’t come on either and doesn’t crank or anything.. any idea what it could be
Slouden28 is offline   Reply With Quote
Old 05-23-2022, 04:38 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I’d really appreciate it if you could post a picture of the starter ground wire. I’m looking into a similar issue which if it applies to you is pretty coincidental!
Check the positive of the battery in the trunk. There’s 2 wires going to the 200A and 350A. I’ve seen a few people have either of those fuses blow when the starter ground wire does that. If it is this, you’ll have to replace that fuse and it should crank right up.
Again I’d really appreciate the starter ground pic and if the fuse is blown please send a pic of that blown fuse as well. I’m attaching what I’m talking about and will include a part number for it below
84081785
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 05-24-2022, 11:56 AM   #3
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
No such thing as a starter ground wire, and if the wire shorted *to* ground, it's clearly not a ground wire.
Rayvan is offline   Reply With Quote
Old 05-24-2022, 12:29 PM   #4
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I agree. There is a cable that bolts to the engine block near the starter on one end and the car body on the other end. This cable creates the grounding link between the engine (including the starter) and the body/chassis.
I (and many others) have found it to be inadequate and have added an additional ground cable. I've attached a link on my thread on that issue. I have no idea if any of that will help your situation but it certainly fixes for many of us any slow cranking starter issues on a warm engine.
https://www.camaro6.com/forums/showthread.php?t=586153
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 05-25-2022, 03:13 AM   #5
Bumbleboy92
Long hauler
I’m not sure the correct term for the wire but he’s right on a wire shorting against the starter shielding. I’ve read previous threads where this has happened. I’m hoping to get a better idea of what wire is causing the short. Whatever that is, it’s causing the rear 350Amp fuse on top of the positive of the battery to blow and incapacitate the car
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-18-2022, 12:00 PM   #6
stormtrooperSS1le
Drives: 2017 camaro ss 1le
Hey Bumble boy-
Did you figure this out yet? I am having the exact same issue as you. I replaced my 350 today and it popped again after trying to start the car. Has to be a short when trying to start. It started ran and tred it again and no luck. Has to be a short on something. I’m going to remove the heat shield off the starter and see what is up. But all the wires around the battery look good.
stormtrooperSS1le is offline   Reply With Quote
Old 06-18-2022, 01:33 PM   #7
stormtrooperSS1le
Here is the start wire that shorting against the starter heat shield
Old 06-19-2022, 11:10 AM   #8
Bumbleboy92
Long hauler
Should be just moving the wire away from the shielding. Everytime it hits the shielding and shorts then the 350A is blown I’d imagine
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-19-2022, 11:41 AM   #9
stormtrooperSS1le
Yea I removed the shielding and will wrap the headers on that side location and get a starter blanket, should be problem solved. Gmpartsdirect has this fuse assembly for 67$
