05-01-2022, 07:47 AM | #1 |
Drives: 2016 Camaro 2SS "Convertibobble" Join Date: Mar 2022
TPMS, and/or How I Avoided a Costly Mistake
Gang,
Short version, has probably happened to others but if not, take an extra moment to be sure: Got in car at end of work day and info system said LR tire was flat. Hmmm, hadn't necessarily noticed; got out, looked fine, like a good doober even threw a gauge on it and all OK at 38psi cold. Got back in car, went to pull out but just before doing so, and for some miraculous reason, I thought, "WAITAMINNIT -- check the other side". Got out, checked RR, bingo! Flat. (Luckily I work for a construction company and we have tire changing equipment on-site, so no major inconvenience issues there.) The car received a brand-new set of tires just before I bought it, so they must have switched the wheels when they mounted the new set. What made me decide to look I have no idea, but boy am I glad I didn't pull out and trash the RR wheel, and who knows what else! Will probs not bother with that "re-learn tool" I've seen mentioned elsewhere, now that I know the rears have been switched. (FWIW was also very impressed with how light the wheel/tire combo was, once off the car.)
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp) '99 4Runner 367K '94 ST1100 146K Last edited by The Chief (tm); 05-01-2022 at 07:49 AM. Reason: Forgot one paragraph. |
05-01-2022, 07:58 AM | #2 |
Good catch.
'16 Camaro 1SS
05-01-2022, 06:58 PM | #3 |
Damn, now I'm worried, I just had my summer wheels put on lol
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
05-01-2022, 08:05 PM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
the scanners are not expensive and so simple to use. I teach my own when every I change sets of tires.
05-01-2022, 09:03 PM | #5 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I think about $15 on Amazon.I will be getting one.My new tires are general g max rs.They are not runflats.
05-01-2022, 10:07 PM | #6 |
Awesome tip from The Chief on double-checking other wheels, thanks
By the way, I bought the $15 relearn tool and have used it a few times, it's a simple and smooth 1-minute process. While it would nicer to have the car autodetect TPMS sensor positions, this really isn't a big deal IMO.
05-02-2022, 07:14 AM | #7 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
The tool cost $12 shipped on Amazon. Process took me less than a minute. Could also swing it by some where like discount tire or even do the classic amazon use+return.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
05-02-2022, 07:56 AM | #8 |
Drives: 2016 SS Join Date: Jan 2016
i got 4 new tires last month, had always check TPMS to make sure they are all in the correct location...well, all 4 of them were in the wrong spot, thanks discount tire.
05-02-2022, 11:29 AM | #9 |
05-02-2022, 10:47 PM | #10 |
Drives: 2022 2SS Join Date: Mar 2022
I had the exact same thing happen to me a few years ago on a Yukon, I always re check / reset myself after a dealership / shop rotation.
2022 Camaro 2SS (6000 Vehicle Delivered to Customer 4/7/2022) Build Date 2/28/2022 GAZ Summit White B04 Black Metallic Rally Stripes IOT Navigation MX0 A10 Transmission CF5 Power Sunroof SLN Strut Tower Brace 56V 20" 5-spoke Carbon Flash Metallic Wheels NPP Dual-mode exhaust VTD 2nd Gen Ground Effects Carbon Flash Metallic 1996 Corvette LT4 Convertible Collectors Ed SOLD 2004 Corvette ZO6 LeMans Commemorative SOLD |
05-02-2022, 11:27 PM | #11 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I don't think Discount will usually reset the monitors unless you ask them. I always do, but got the re-learn tool anyway. Helps if you do a rotation after new brake pads or some other maintenance.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
05-03-2022, 04:20 AM | #12 |
My dealer will do the TPMS for free. All I have to do is drive in, and they do it in about 3 min, no waiting.
05-04-2022, 03:55 AM | #13 |
L8ap3x
05-07-2022, 09:45 PM | #14 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I also know of someone who got a flat on track and checked the indicated side in hot pit and saw nothing wrong then proceeded to go back on track with a flat on the other side and blow it out. This thread is very good advice. |
