TireRack
Old 01-11-2022, 08:05 PM   #1
Samspeed
Drives: 2010 2ss
LSA conversion on an LS3
I’m going to use an LS9 powermax cam and was wondering if anyone had used it.
It recommends a pac 1218 spring but the cam is .600” lift, will that work?
And can I use the stock LS3 pushrods?
2010 2ss 6 speed
Mods will be LSA Supercharger with a 2.75” pulley, LS9 powermax cam, CAI, LT Headers any help would be appreciated!!
Samspeed is offline   Reply With Quote
Old 01-12-2022, 07:20 AM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I do not have any experience with that particular camshaft. I'd feel comfortable using their recommended spring, PAC 1218, as well as re-using the stock pushrods. As long as you are sticking with a single spring, stock pushrods should be just fine.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 01-12-2022, 07:32 AM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
As long as the base circle of the camshaft is the same as the stock cam, then the pushrod length should not change. The base circle of the cam is the smallest measurement you can get on the cam lobe.
But instead of guessing you should spend $30 and get the tool.
https://www.summitracing.com/parts/cca-7702-1
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-13-2022, 12:00 AM   #4
Samspeed
Drives: 2010 2ss
Thanks for the advice!
