11-23-2021, 03:01 PM | #1 |
Drives: Monte Carlo ss Join Date: May 2021
Ls3 Asa cam..
Hey guys, I have a Ls3 with a Howard's ASA cam, gmpp dual plane intake an 950 quick fuel carb..thinking I left quite a bit of power on the table with that cam( maybe I am wrong)..need some advice of a gpi ss3 or cam motion titan or junkyard dog rectangular port cam?? Will there be a significant power difference to justify the effort??
11-24-2021, 10:44 AM | #2 |
With a stock ls3 intake and EFI, 2 inch headers, 3 inch exhaust and the 110 version of that cam, my car made 502whp on a Mustang dyno in excellent weather. (here is one example of a high reading mustang dyno. everyone swears they read low). I dont believe the dyno numbers myself. I think it was probably more like 470ish. I also used it in with a centri supercharger and made 913whp on a dynojet.
There is another member on here who made 486whp with this same cam. This is about what most bolt on cam cars make. Generally speaking, there are much better cams out there. I liked it because it required very little additional spring pressure than stock. I just threw in a set of slightly stiffer beehives for $120. Unlike stiff spring sets that should be changed every 20k miles. I dont know how it would behave in your setup. But I'd guess you're probably looking at 20whp.
2011 Camaro SS---SOLD
11-24-2021, 12:29 PM | #3 |
Thanks for the insight, that's what I was wondering (hp) if it would be significantly more..car is mostly street driven an was curious if it's worth a swap to a bigger cam
11-24-2021, 12:30 PM | #4 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
11-24-2021, 02:32 PM | #5 |
Thank you cammer! Been looking at that ss3 for quite a while now an may have to pull the trigger on that cam
11-24-2021, 03:29 PM | #6 |
I can pretty much tell you anything you want to know about that one, both from our GPI perspective, as well as my personal perspective. I have had that cam in my 2011 M6 Camaro since 2018.
11-24-2021, 07:48 PM | #7 |
Hey cammer, I got a 3200 stall converter with 3.73 gears..you think that would work with the ss3?
11-24-2021, 09:23 PM | #8 |
Drives: 2012 SS Join Date: Feb 2016
I have a Howard's asa cam on a 113 lsa. Yes I fully realize that there are more powerful cams out there & I am considering upgrading in the future. But for now it is good. I run it with Pac 1218 springs. It is a very driveable cam. Other that a light chop at idle it drives absolutely like stock. gave me a nice little bump in power & with my LTs & Npp exhaust, sounds fantastic. Get compliments all the time. So overall it is not a bad cam at all.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
11-25-2021, 03:54 PM | #9 |
Drives: 2015 1LE Join Date: Oct 2015
call GPI and talk to them, they have done it all
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
11-25-2021, 08:45 PM | #10 |
Got your message on our help-desk and responded. I'll answer briefly here as well for those interested in the info - the SS3 will work with a 3200rpm stall and drive fine. Ideally, that cam would like more like a 3600-4000rpm stall to best fit it's torque curve and provide maximum acceleration from a dig, but the 3200 isn't a huge sacrifice in performance and for a fun cruiser is just fine.
11-25-2021, 10:46 PM | #11 |
The ASA cam is what's in the 525hp crate engine from GM. Most stage 3ish cams make 560ish at the crank.
11-26-2021, 07:55 AM | #12 | |
11-26-2021, 11:38 AM | #13 | |
11-26-2021, 01:33 PM | #14 |
Thank you everyone! Some really good information! I like a nasty chop at idle, just a street weekend car..an have to make my decision pretty quick since there's some black Friday Deals going on!
