11-07-2021, 10:51 AM | #1 |
Drives: Camaro Conv. 6.2 SS - 2014 Join Date: Jan 2018
Mounting clips rear bumper - broken
Hello,
when installing the new exhaust system and removing the rear bumper, the previous owner's shop must have broken off a clip/bracket on the rear bumper. Attached are two photos that illustrate the problem. Unfortunately, due to the missing bracket, the rear bumper no longer sits perfectly under the taillight, and sticks out a bit. If you know it, it is extremely annoying. Does anyone have an idea how to solve the whole thing somehow? For this a new rear bumper is not really worth it. Thanks a lot Dennis |
11-07-2021, 06:39 PM | #2 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
Hi Dennis. Google "Bumper clip repair" or "Plastic clip repair" Lots of good info out there.
Levon H. Bone Stock |
11-07-2021, 11:06 PM | #3 | |
Drives: 2010 Camaro 2SS Join Date: Sep 2015
Maybe this page shows you what part is broken or missing. I would remove the tail light and you may get a better idea of what to do with it if the bumper cover is actually broken. With the tail light out you can see what may be possible to make a repair of your own without bumper cover replacement. You can see in the parts diagram that it is part #6 that snaps into that bumper section. Watch the video and you will see the area you need to fix.
https://www.gmpartsnow.com/v-2014-ch...omponents-rear Last edited by davesnever; 11-07-2021 at 11:28 PM. |
11-08-2021, 01:27 AM | #4 |
Drives: 2010 LS Join Date: Feb 2021
Happens up front too, so I bolted mine on. I used real small Stainless Steel domed hex
head fasteners. |
11-09-2021, 03:00 AM | #5 |
Thank you very much for your answers.
The easiest option will probably be to "rebuild" the broken clip with polypropylene and a heat gun. I do not have all the tools as in the videos, but it is not about a professional repair, but only that the clip works again. |
12-06-2021, 07:28 AM | #6 | |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: May 2017
Left:23186325 https://www.gmpartsdirect.com/oem-pa...acket-23186325 Right: 23186324 https://www.gmpartsdirect.com/oem-pa...acket-23186324 These are for the 2014-2015, and I hope that is right for you. The part name is "Side Bracket". Good luck.
StarSaber Mk. II
IG: StarSaber85(https://www.instagram.com/starsaber85/) Performance Mods: CAI, Inc. Cold Air Intake; ADM Racing Scoop; Bo White Ported Throttle Body; GPI Ported Rod Mod Intake; Kooks 1-7/8" Headers with Catted Connections; Solo Mach XL Axle-Back Exhaust |
