10-22-2021, 04:27 PM | #1 |
Drives: My wife nuts... Join Date: Sep 2011
What's the avg weight savings from an axle back system?
3-5lbs less than the factory suitcase or is it more ?
10-22-2021, 07:25 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
i think the npp systems differ less than that. i also think full exhaust weight is negligible across all options that use a muffler bigger than your fist.
2016+ camaro: everyone’s first car
10-22-2021, 07:58 PM | #3 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
weight loss
Replacing the suitcase with an axle back system that has for instance MAGNAFLOW mufflers is closer to 20 pounds LIGHTER than stock.
To give you a more precise answer, I lost 40 pounds of weight when I replaced the stock headers with KOOKs headers and off road pipe and Magnaflow back half system. My 2019 SS2 1lE is now at a DRY weight of 3614 pounds including the APEX wheels which are 2-3 pounds lighter per wheel. I also have ZL1 brakes though which do add some weight.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
10-23-2021, 12:31 AM | #4 |
Drives: 2016 SS Join Date: Jan 2016
i saved about 25# doing a muffler delete
10-23-2021, 01:59 AM | #5 |
Drives: 2021 LT1 A10 RS Join Date: Feb 2021
On non NPP it was surprisingly only 6 lbs, on my LT1. I went with the GMPP exhaust, Borla S Type built.
10-23-2021, 06:08 AM | #6 | |
330 & 12 mins for those that don't want to watch a dude weigh a bunch of stuff. the magnaflow npp is 1 lb lighter than factory npp.
10-23-2021, 07:47 AM | #7 |
I don't know if the LT1 OEM axleback is the same as the ZL1, but my axleback weighed ~42 and my Kooks AB weighed 22, and there's several different Kooks AB that presumably vary in weight
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
