09-30-2021, 09:16 PM | #1 |
Drives: 2021 Camaro 2SS Convertible Join Date: Mar 2021
Continental extreme contact all seasons on an SS
A general question: does running all season tires on an SS compromise traction on a hard acceleration? The stock summer only tires on my SS hook pretty well, but I need to switch to all seasons for the upcoming winter. Will traction suffer on dry roads with the all seasons under fairly hard acceleration? ( I don’t think I’d ever try hard acceleration with all seasons)
In particular, anyone running Continental extreme contact all seasons? If so, do you like them? Any other all season recommendations? It’s my first winter with my new SS so any recommendations would be appreciated. |
10-01-2021, 06:51 AM | #2 |
The DWS06 (and the newest DWS06+) are quite popular and of course there's a traction give up over a summer to gain winter capability, you can def break them loose easier but tires in that Ultra A/S category are quite good in a lot of ways.
10-01-2021, 12:12 PM | #3 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I've had them since the fall of 2017 and I love them. You will give up some traction but I don't mind because I want to drive my car in all weather.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
10-01-2021, 03:53 PM | #4 |
I had the General AS-05. Traction is an issue if you're doing hard launches. Otherwise, the tires put the power down pretty well.
'16 Camaro 1SS
10-01-2021, 07:09 PM | #5 |
Oldman w/a teenager brain
Drives: 2022 ZL1 A10 Join Date: Mar 2021
What the others have said. You’ll just have to get used to them on under what conditions they’ll break loose. They’ve been satisfactory.
10-01-2021, 07:58 PM | #6 |
Thanks for the comments. I figured I’d be giving up some traction, but I’ve got to drive the car all year. From the little I’ve read, the Camaro seems to do ok in the winter. I guess the snow/ice mode works pretty well.
10-04-2021, 09:13 AM | #7 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
I used snow/ice mode into the mountains too ski in a snowstorm and around DC for the snow, it definitely works - still need to be wary of sudden changes and braking is well always an issue in the ice.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
10-04-2021, 10:54 AM | #8 |
10-04-2021, 12:21 PM | #9 |
You can moderate traction on snow/ice with a 2d gear start (assumed manual tranny)
10-06-2021, 02:22 AM | #10 |
Drives: 2016 camaro Join Date: Mar 2018
The DWS06 are great in the wet and dry. Had these tires and I was pleased with their performance.
10-06-2021, 06:38 AM | #11 |
The only neg that I've heard in the past was the sidewall is soft, doesn't handle all that well when pushed.
10-08-2021, 05:53 PM | #12 |
Drives: Duramax, 2018 Camaro SS 1LE Join Date: Nov 2020
I got a set of EXTREMECONTACT DWS 06 PLUS installed last week.... I like them better on the streets then the Good Years.
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
10-12-2021, 10:07 AM | #13 | |
Drives: 2010 Camaro SS Join Date: Sep 2012
So far, I am impressed with the tires overall. They don't mind wet roads, but watch out for puddles. It will grab the steering wheel out of your hand. |
10-13-2021, 08:39 PM | #14 |
Instead of ditching your good-performing summer tires, you could buy a second set of wheels and tires just for winter. For example, there's a guy in our Classifieds section selling a mounted and balanced set of Blizzaks on nice wheels with TPMS, ready to go for a nice price. He's in Wilkes-Barre, so not far from you. That whole setup is probably as cheap or cheaper than a set of Conti DWS tires, and then you get to mount your sticky tires back on the car in the spring.
Matt Miller
2020 SS 1LE |
