09-12-2021, 08:49 PM | #1 |
Drives: Camaro 1LE Join Date: Jan 2020
Stock or aftermarket intake mani.
Looking at stock/rod mod or aftermarket in general. Holley/MSD? Any recommendations would be appreciated.
09-13-2021, 12:06 AM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
Stock. I can't think of any composite aftermarket LS3 intakes other than FAST. GM did very well in the LS3 intake's design.
09-13-2021, 01:14 AM | #3 |
Boosted Moderator
Stock… Untouched…
I made 1400 RWHP through one, ~~1700 on spray through it… My opinion, based on what I’ve seen at the shop where my car is built and maintained, Do not use FAST intakes with boost… ok, Moderate boost, up to say 8 lbs, maybe, but why spend a grand on an intake for no gains and possible headaches when the factory piece is amazing… Is the factory piece perfect for boost, no… but it’s better than most anything you’ll buy and pretty much bullet proof… I only got rid of mine when we built a custom one off sheet metal intake for very high boost and high RPM’s…
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
09-13-2021, 08:30 AM | #4 |
Not even the rod mod?
09-13-2021, 11:38 AM | #5 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
The rod mod is not designed for boost. It removes a lot of the integrity of the intake. When air is being drawn it vs pushed in, it's more of an issue. So stock gets my vote as well.
If you had to get an intake, the lo ram/hi ram or ideally the surge/btr equalizer 3 takes the cake for distribution/power
09-13-2021, 11:41 AM | #6 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
There you go. 3 of the fastest dudes on here all vouching for the stock Intake.
09-13-2021, 01:22 PM | #7 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
It's hard to beat the performance of the stock LS3 intake, very hard. For me it was good up to 17psi boost.
09-13-2021, 01:41 PM | #8 |
Like stated if you don’t boost rod mod is the best, if you gonna boost either stock or Holley high ram
09-13-2021, 10:37 PM | #9 |
Guess that answers that.
09-14-2021, 09:54 AM | #10 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
I threw away my junk ass holley sniper low pro, FAST fell apart before I installed it. BTR Equalizer 3 is a quality piece of equipment.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
09-14-2021, 12:19 PM | #11 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I swapped out my holley low pro back to stock style.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
09-14-2021, 07:17 PM | #12 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I run a stock ls3 manifold anf throttle body on my 427 TT setup.
More to come. |
09-14-2021, 07:18 PM | #13 |
2&THEHIT
I was gonna go with the BTR purely for looks, but the numbers just aren’t there. It is definitely a looker though.
If I do change, I’ll probably go with a Victor style with elbow... and a new hood for it to fit under. |
09-14-2021, 08:03 PM | #14 |
At what point will the stock mani be restrictive?
