08-14-2021, 08:34 AM | #1 |
SNSTRSS
Modifying Valve cover
I currently have a catch can that attaches to the oil fill opening. I would like to relocate it to a dedicated 10-an fitting on the driver's side valve cover. I see on the cover there is a high section that I would like to use. My question is, do I have to mess around with the internal baffle? Should I drill from the top of the valve cover through the existing baffle, and then is there enough clearance to rivet in a custom baffle over the new hole? If anyone has done this I would greatly appreciate your input. If you have any pictures you would like to share, that would be great. TIA
2016 Black Camaro 2SS A8 NP
08-14-2021, 11:00 PM | #2 | |
08-15-2021, 09:42 AM | #3 |
SNSTRSS
I understand that, but I would like to add a 10an fitting to the valve cover for my catch can set up. Not sure how to do It with the current baffle in place.
08-15-2021, 11:16 AM | #4 |
If you're running the MM Wild, it just goes right into the existing oil fill spot with their adapter. No need to hack anything up. Easy peasy.
08-15-2021, 04:03 PM | #5 | |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
This. MM did all the work for you.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
08-15-2021, 05:23 PM | #6 |
SNSTRSS
I don't want to use the MM oil fill cap location. It is a hassle to remove to add oil when you have a procharger on the car. The filter location is right up against it.
08-16-2021, 06:22 AM | #7 | |
Drives: '16 2SS Join Date: Feb 2017
Before I would take off the strut tower brace and procharger air filter and blah blah blah… now it’s just maybe a minute more of work to undo the one fitting and done. |
08-16-2021, 07:52 AM | #8 |
BAMF SS
Seeing how you have a procharger, and probably have that vacuum line running from your factory catch can all the way to the filter on your procharger, I'd suggest the following.
Sell the MM Wild Catch can (the cost of redesigning it outweighs the cost of a new one) Buy a quality catch can by itself.... Motion Raceworks makes a solid one Remove/plug factory catch can Instead of the new catch can routing to your oil cap, have it route to the two fitting on the valve covers that were intended for the factory catch can.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
08-18-2021, 07:08 PM | #9 | |
Does the motion raceworks vent crankcase pressure somewhere other than in the engine bay, along with all the oil the CC caught? |
