06-21-2021, 01:16 PM | #1 |
Drives: 15’ Chevy Camaro Z/28 Join Date: Jun 2020
Camaro Fest events
Ok my Z family I have questions. I’m preparing the car for Camaro Fest in a couple weeks and I was going over the track prep guide geesh🤦*♂️. I’m doing a Novice/beginner class at NCM road course and then the next day doing the autoX event. Not looking for trophies or to be really competitive just wanting some experience and fun and to learn and enjoy the car. Now I have new tires and Im about to do the other prep but is it really necessary? I get the oil change and filter (PF64) that’s a given. But will the stock brake fluid, coolant, and diff oil all be ok without changing and just making sure they are topped off? I have just over 12k on the car but don’t know if the car was ever tracked before. Also does anyone know the thickness of the stock (new) brake pads? Was going to check those as well even though the brake feel just fine. I guess I am just wanting to know what is a must and what isn’t. I don’t track the car ( 1st time ) and it’s a weekend warrior/car show cruiser not a daily. Any help is greatly appreciated thanks
06-21-2021, 06:13 PM | #2 | |
Build Date - Dec 08, 2014
Drives: 2015 Z/28, #1007, Black A/C Stereo Join Date: Oct 2015
06-21-2021, 08:43 PM | #3 |
Drives: 2015 Z28 #141 Join Date: Dec 2015
Everything AustexaSS said is accurate--but may be a little overkill for your first time out. As far as safety goes, you should do everything you have the time and resources to do--but a lot depends on how hard you drive (or plan to drive) the car. I will say that no matter what the oil/filter, diff fluid, brake fluid and pads need to be new or nearly new. Even stock brake fluid is probably fine as long it is fresh. You said the car has 12K miles on it and you don't know if it has been tracked, then if you are not 100% sure of the condition of those parts then replace them. You asked about the pad thickness--I just changed mine but don't remember how thick they are (the car is in storage, so I can't go check). From memory they were around 3/8"--don't quote me on that, but it's something if no one else chimes in. I am assuming they are providing loaner helmets, if not make sure you have one.
If you are a 'full send', 'red mist' kind of driver, then definitely do everything that AustexaSS said. But if you have never got your oil temp anywhere near 285, or have never got enough temp in your tires to add 4-6psi to the cold pressure--then you should take it easy your first time out which will require less prep. Beginner groups are always relatively slow anyway. Learn the track, get used to going fast around other cars, have fun. I seriously doubt you will use 50% of the car's ability your first time out--no matter how fast you think you were going. After this experience you will have a much better idea of how much safety/car prep you want to do. I drive my cars 10/10ths on the track--and I do pretty much everything AustexaSS does--but that was not how I started. over the years, I added things to my prep/safety equipment list as I got faster and drove more aggressively. 20 years ago, my track prep was to jump in the car, fill it with gas and drive to the track--and hope it didn't break down on the way! But back then my car was slow and I drove it slow. I looked at the track map, and that Grand Full Course looks fun. It has some high speed sections, but you are not required to fully send it all the time--just stay off line and learn to point by if you are not ready to go that fast. I'm sure the organizers will cover all that stuff. The lower speed sections look like they will be challenging and fun regardless of your experience level. Have Fun and Good Luck!!! |
07-03-2021, 05:28 AM | #4 |
I will also be running the CamaroFest track day in my Z. I have run the course before and regularly run HPDE events. If you need any help or advice don't hesitate to come and say hello.
