Old 06-20-2021, 10:53 AM   #1
DCZ1LE
DCZ1LE's Avatar
Drives: 2015 Camaro 2SS 1LE
Head Gasket Orientation
EDIT: Pointless question, they are symmetrical.
1/12th of a turn is all I need.
DCZ1LE is offline   Reply With Quote
Old 06-20-2021, 01:39 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
That's ok your just talking out loud and sometimes that's what it takes.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 06-21-2021, 01:06 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Just put the FRONT on the front of the motor and you are done, dont over think it
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 06-21-2021, 02:40 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
What he said ^^^
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-30-2022, 09:08 AM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Old thread, but not too old
... Anyone know why it matters? Does "front" mean front of the engine or front of the gasket?
There's only one set of jacket water holes. Do they go to the rear of the engine?
Old 10-30-2022, 01:41 PM   #6
Bo White
Bo White's Avatar
The gasket is designed to help direct coolant flow correctly.
The front coolant passages are closed off for the most part so that more coolant will be directed towards the back of the block so to cool the rear cylinders. If the gaskets are installed backwards most of the coolant flow will be mostly in the front of the block and cylinder heads causing heat issues for the rear cylinders.
Totalled:
Bo White is online now   Reply With Quote
Old 10-30-2022, 08:34 PM   #7
joshnmn
2&THEHIT
joshnmn's Avatar
That's what I thought Bo. Thanks!
