06-13-2021, 07:51 PM | #1 |
Drives: 2015 Camaro 2SS 1LE Join Date: Nov 2014
Cam damaged enough to replace?
I think the cam is scored. Can I get opinions on whether it needs replaced based on pics of the cam lobe?
It appears to be scored on the lobe, looks good on the base circle. Do cams normally develop this kind of scoring over time?
1/12th of a turn is all I need.
06-13-2021, 07:54 PM | #2 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
It is junk
06-13-2021, 08:24 PM | #3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
I wouldn't chance it.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-13-2021, 08:24 PM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Yeah... that's not good. If you don't replace the cam it will wreck your lifter. Time for a new cam...
603 h.p. 495 ft lbs tq. |
06-13-2021, 08:31 PM | #5 |
Thank you all for the quick replies. I was hoping maybe, just maybe that was normal.
I'll get me a new cam.
06-15-2021, 06:25 PM | #6 |
Yep, that one is trashed for shore!!! The pistons can be cleaned up, but carefully so nothing gets down around the rings..
06-15-2021, 09:02 PM | #7 |
Got it, thanks for the advice.
06-16-2021, 10:11 AM | #8 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Is it just me or does it look like a valve may have kissed the piston?
06-16-2021, 04:25 PM | #9 |
Drives: T Join Date: Mar 2015
06-16-2021, 04:29 PM | #10 | |
I definitely noticed that.
06-16-2021, 06:41 PM | #11 |
I missed that one guys!! Good eyes on the valve deal..
06-17-2021, 07:56 PM | #12 | |
Thank you all for taking the time to read and comment. New parts supposed to arrive tomorrow. Fingers crossed they don't get delayed until next week.
