06-11-2021, 02:36 PM | #1 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
Adhesive Coming Through Top
Anyone else have what appears to be adhesive coming through their top? I've had this issue for a while, but I keep forgetting to post about it. It started after my B2B expired, so I've never taken it to the dealership for this issue. It's in a few spots but only on the driver's side. See pics.
2016 Camaro 2SS, Convertible, Summit White, A8, NPP, NAV, Daily Driver (Sept. 2016-Present)
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
06-15-2021, 10:23 AM | #2 |
Thank you Al Oppenheiser!
That looks like bleaching from mildew after being folded wet.
06-15-2021, 02:54 PM | #3 |
Thanks for the input, but it's definitely not mildew or bleaching from mildew. Top is always up when parked, and I let it dry out in the sun before putting it down after washing. It has some stickiness to it, so I believe it's adhesive of some sort that is bleeding through.
06-15-2021, 03:23 PM | #4 | |
Hot Camaro
06-15-2021, 06:16 PM | #5 |
Drives: Former Owner '16 Camaro 2LT V6 conv Join Date: May 2021
Salt related? Looks similar to my golf hat. It gets soaked with sweat then dries, and I don’t really wash it. Makes a salt ring.
06-15-2021, 11:42 PM | #6 |
Drives: 2017 Convertible 1SS A8 Join Date: Aug 2018
I don’t have this issue on my top. But have you tried using a convertible top fabric cleaner and a soft brush to clean those areas, then applying a convertible top fabric restorer? That should help remove the stains and darken those areas so they are less noticeable.
Kooks 1 7/8" LT catted headers, Katech Ported TB, SoCal ported IM, Green filter, Tuned by BCP, Borla S-Type axle-back, BMR springs, BMR front sway bar endlinks.
06-16-2021, 09:46 AM | #7 | |
Hot Camaro
A little bit of white vinegar on it might help to expose whether it's mold/mildew and start the process of getting it corrected. |
06-16-2021, 10:05 AM | #8 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
06-16-2021, 03:13 PM | #9 | ||||
Thanks for everyone's input.
06-16-2021, 03:56 PM | #10 | |
Hot Camaro
I don't think it's from something like a grease or oil because that would seemingly also attract dirt. If the white vinegar seems to be helping (try lightly spraying it on in an area and letting it air dry then brushing that area), then it may very well be a mold/mildew type of stain. |
06-16-2021, 06:57 PM | #11 | ||
06-17-2021, 09:19 AM | #12 | |
Hot Camaro
One "test" you could try would be to do what you typically do with washing and drying. Once you are comfortable that the top is completely dried out (and you may want to check the underside in those areas too to be sure water isn't actually getting -under- the canvas), put it down. Wait about two minutes, then bring it back up. See if there's any sort of moisture in those areas. |
06-17-2021, 10:33 AM | #13 | |
Still looks like water/mildew type stain to me but because the OP said it's sticky, here's a WAG: Collection of soap residue after it got wet. Another WAG: possibly excess grease dripping out of the back of the left side latch (if that's even possible)? Would have had to have be pretty hot though and lithium does not drip ... which doesn't seem likely unless the car sat in the heat with the top folded for a long time. Or a hydraulic leak on the driver's side that sprayed oil. OP, is there any evidence of oil/water spray around the driver's side lift mechanism under the tonneau? Last edited by Gunkk; 06-17-2021 at 10:46 AM. |
06-18-2021, 07:34 AM | #14 |
Drives: 2017 2SS Convertible Join Date: Mar 2021
Hi All,
Have you considered a sap from parking under a tree? Is sticky, when it dries it has similar color. Could get on the top unseen and then folded and smeared over the folds. Sap may be a bitch to clean though.
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) |
