05-31-2021, 03:50 PM | #1 | |
Drives: 2021 SS 1LE SHOCK Join Date: Mar 2021
Clutch wear video on Youtube
I'm really impressed with the clutch wear on this guy's SS 1LE, especially after all the no lift shifts. He says he has 22K miles on it and it looks barely used
05-31-2021, 07:18 PM | #2 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
The no lift shift is a supported feature for track/drag use that AFAIK doesn't hurt the clutch at all, so I guess that aspect of little wear isn't surprising. The ECU cuts torque while you are shifting. I guess it just improves the torque response time compared to moving the accelerator pedal yourself.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Camaro ZL1 1LE (Red Hot) - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
05-31-2021, 08:40 PM | #3 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Did you know if you leave from a dead stop don't touch the throttle and the car will maintain 1000rpm and will not stall...
2017 1LE Hyper Blue
06-01-2021, 12:25 PM | #4 |
Yes sir! I taught my daughter to drive a manual in my 1le because all she had to do is easily let off the clutch until moving then give little gas and off she went.
06-01-2021, 06:16 PM | #5 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Is it necessary to turn on Rev Match to use NLS to its best?
06-01-2021, 07:26 PM | #6 |
Rev match is brilliant. I'm not sure why you wouldn't use it. No matter if it's tracking or day-to-day driving, it's better.
Rev match is different than NLS or launch control.
06-01-2021, 08:36 PM | #7 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Saw the video also. Thought it was funny that in the previous video he swore the clutch was toast.
06-02-2021, 01:54 PM | #8 | |
My question was, if it is necessary to switch Rev Match on, in order to enable NLS to work as intended. |
06-02-2021, 03:06 PM | #9 |
06-02-2021, 07:54 PM | #10 |
Drives: '18 1SS 1LE Join Date: Sep 2017
NLS is automatic at WOT above the enable rpm, which is 5000 on the 1LE.
Rev match is selectable and unrelated to NLS, and works during up and down shifts.
'18 1SS 1LE Black, PDR
06-02-2021, 08:04 PM | #11 |
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
Forgive my ignorance but I apparently don't get this properly. I tried in my 2018 SS 1LE today. Engine on at idle, dead stop, not touching gas, release clutch, car stalls. Are you saying that it should pull off and maintain 1000 RPM in that use case? I was replying to post #3 that indicates we can start off with no gas modulation.
06-02-2021, 08:13 PM | #12 |
Drives: 2017 1ss 1le Join Date: Feb 2018
Me too. I think people are saying u can get it moving with no gas and just release the clutch slow. The car will not keep the rpms up for u. At least what I have tried.
06-02-2021, 09:04 PM | #13 | |
2017 1LE Hyper Blue
06-02-2021, 09:11 PM | #14 |
2017 it for sure will maintain rpm..
2017 1LE Hyper Blue
