05-10-2021, 09:26 PM | #1 |
Sarcasm loading --------
Possible oil pressure issue
My car odd oil pressure lately.
when it was new it had about 40 psi at idle warm. after a few thousand miles it went down a little to about 30 psi at warm idle, and at higher RPM it seemed to never go over 45ish on the display. I took it to the track recently, and changed the oil to the thicker oil. I rarely drive the car, and the oil is still in it. I drove it today and the oil pressure at a higher rpm is more than before; to what I would say is normal (50+), but its lower at hot idle than ive ever seen it - around 20-25 psi. The car has 14k miles on it. I think its low, compared to what it was new. what is normal oil pressure on these engines? do you think it may have an issue?
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-10-2021, 10:14 PM | #2 |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Sounds like your oil pump is starting to fail. The pressure should be around 28-30psi at hot idle. This thread basically verifies that. https://www.camaro6.com/forums/showthread.php?t=532479
There's a chance it could ruin your engine if the pump fails while you are driving. I would bring it to the dealer and explain the situation. What's the build date on your car? |
05-10-2021, 10:36 PM | #3 | |
I bought it new in august 2017.
05-10-2021, 11:11 PM | #4 |
2020 Shadow Gray 2SS
You should still be under the powertrain warranty, take it to a dealer and get it checked, the LT4 did have an oil pump failure issue...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
05-10-2021, 11:18 PM | #5 |
Most of the failures occurred in the 2017s. There's a gray sticker on the driver side door jamb with the build date. It's only a matter of time before your pump fails completely, which could be catastrophic.
05-10-2021, 11:26 PM | #6 | |
I'll take it to the dealership to be looked at.
05-11-2021, 06:40 AM | #7 |
Don’t know if the dealer will do anything for you except make a notation with your vin since you haven’t had a failure yet! Good luck and I’m keeping a watch on my 2017 every time I drive it now wondering if it will fail too. Mine has around 19,000 miles so far.
05-11-2021, 07:35 AM | #8 |
Drives: 2023 SS 1LE Join Date: Mar 2020
That’s the tell tale sign of impeding ‘total’ pump failure I’m told... once the hot idle shows 20 PSI, the cracks have occurred and the next step is total failure and potentially catastrophic engine damage. I would definitely not be driving or starting it anymore. Flat bed straight to the dealership. You may have gotten ‘lucky’ and caught it before it totally ruptures and sends debris into your oiling system. Most guys don’t even get that or don’t notice that low pressure until it’s too late.
Here’s my 18 ZLE at hot idle. Always seems to stay right at this 30 PSI mark. This is Mobil 1 Extended Performance 5W30 oil. |
05-11-2021, 07:58 AM | #9 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Which weight oil is in it and did you track with that oil. I think your pump is OK but I would change oil IMMEDIATELY.
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
05-11-2021, 11:23 AM | #10 | |
05-11-2021, 03:50 PM | #11 |
I am just going off what I was told by people who have had the oil pump failure. I won’t say it’s the definitive symptom. I’m not sure if there is one. I’ve read also where the oil pump just goes all at once, with no symptoms of pending failure. Who knows for sure? I will say that my 2018 ZLE holds steady at 29/30 psi when hot. And that’s with oil temps at 260*+ from ‘spirited’ driving. Is this normal? I don’t really know. With these pumps known to fail, if I see it drop to 20 psi or below, it’s going straight to the dealership to open a case file with GM noting the issue while it’s still under warranty.
05-11-2021, 06:25 PM | #12 |
Yeah I know what you are saying. It’s a shame we have to keep our eyes on the oil pressure gauge while driving! I surely don’t have to do that driving around in my 2005 Silverado truck with a 4.8 liter V8 LS variant engine that has over 96,000 miles.
05-11-2021, 06:31 PM | #13 |
And I use 5w30 Valvoline Synthetic in the truck and 5w30 Lucas Synthetic in the Camaro. Last oil change I did I used Lucas in the ZL1 just to try it and might go back to Valvoline though next oil change.
05-12-2021, 06:08 AM | #14 | |
Drives: '18 ZL1 1LE Join Date: May 2020
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
