05-09-2021, 04:04 PM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Service Rear Axle?
Hey everyone took the car out this morning and got a notification on the dash that said "service rear axle", car only has 4,000 miles on it and it seems to be running fine. I clicked "dismiss" turned the car off went inside the house for a few minutes came back out and it didn't come back up when I started it again. Is it a fluke? or should I be concerned about something? Thanks for any help!
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
05-09-2021, 04:11 PM | #2 |
Thank you Al Oppenheiser!
Yes a fluke.
A momentary low voltage condition can trigger a service rear axle notice, among other things. The computers in our cars really don't like low voltage at all, and can/will throw errors even when there is actually nothing wrong. If you don't have a CEL, don't worry about it. |
05-09-2021, 05:21 PM | #3 |
Drives: 2021 Camaro ZL1 Join Date: Jan 2010
Change It
It’s probably low. Don’t trust factory line workers FYI use AC Delco |
05-09-2021, 08:16 PM | #4 |
Change the axle?! I already changed out the fluid a couple of months ago and today is my first issue. Hopefully it is just a fluke,will keep my eye on it.
05-10-2021, 06:09 AM | #5 |
Typical reasons to see this are funky battery voltage and sometimes it will pop up when you have misfires (causing a flashing CEL). If you didn't have flashing CEL, just ignore and move on with life.
05-10-2021, 06:53 AM | #6 |
I had it one time happen and never came back on again.
05-10-2021, 09:50 AM | #7 |
Drives: '17 ZL1 A10 Join Date: Jun 2020
Plug a code scanner and check for pending codes. If there is a p050d or p0300/p0301 - 308 pending then it can and will set the service rear axle and or stabilitrak indicators.
No clue why those codes cause the other warnings. |
05-10-2021, 10:54 AM | #8 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
As stated. Low voltage or misfire. Has happened 3 times to me over 18,500 miles. Message appeared, disappeared, poof!!! If no CEL, no worries.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
05-12-2021, 11:42 AM | #9 |
Drives: 2019 Chevrolet Camaro ZL1 Join Date: Mar 2020
I have had this happen three times. I receive that message when my car misfires. I have had the spark plugs replaced each time.
https://www.camaro6.com/forums/showthread.php?t=587629 |
05-12-2021, 03:15 PM | #10 | |
05-12-2021, 11:08 PM | #11 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
If you have the original battery, you may want to consider replacing the battery. I received a transmission error, and an E-Diff error on my 2020... replaced the battery and has been perfect since.
Best Regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
08-07-2021, 09:55 AM | #12 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
I posted this on another thread but I am posting it here as well. I noticed this message today. After driving the car for about an hour, I arrived at my destination. I was backing out of the parking slot shortly after putting it in D, trying to adjust the parking position of the car. I also noticed that for a couple of seconds, before the message appeared on the dash, the steering wheel was not responding very well - it felt hard to turn. I switched off the engine and then I turned it back on and the message disappeared. I drove the car for about an hour and a half with no issues. After going through several threads in this forum, it seems that this an issue related to the ZL1.
Red Hot 2020 Camaro ZL1 A10 <-- Enjoying the hell out of it
Mosaic black 2018 Camaro 2SS A8 (sold) |
08-07-2021, 10:49 AM | #13 |
Drives: 2017 ZL1 Join Date: Apr 2020
If you haven't serviced it yet you are past due. The breakin fluids need to be changed
2017 ZL1 M6 Silver Ice Metallic
08-07-2021, 11:00 AM | #14 |
Makis
You mean service the rear axle?
The car has only 5000 miles on it and it has been through the regular service schedule.
