03-31-2021, 10:56 PM | #1 |
2018 Convertible ZL1
Will tuning void my warranty?
I have a 2021 Camaro LT1 and I am interested in tuning and dyno. Will having my car tuned void my warranty?
03-31-2021, 11:47 PM | #2 |
Drives: 2018 ZL1 1LE Join Date: May 2020
Yes, Tuning does void warranty
04-01-2021, 12:04 AM | #3 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Only the power train portion of the warranty.
04-01-2021, 12:26 AM | #4 |
2020 Shadow Gray 2SS
Yes. (that is a period, so, YES.)
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
04-01-2021, 05:30 AM | #5 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Any tuning will kill it. Soon tuning will be done away with anyways.
04-01-2021, 07:12 AM | #6 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
This is what I’m worried about. I’m thinking about pulling the trigger earlier then I planned so that I can get it tuned.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
04-01-2021, 07:32 AM | #7 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Wait until you add mods that require a tune, typically that starts with long tube headers. That way you won’t have to get tuned again when you mod for the first time. When you do get a tune, make sure you invest in a dyno and street tune. Simply tuning off the dyno leaves HP on the table and can result in some drivability issues. Tuning a totally stock vehicle will pick up some HP but it is not a cost effective option in my opinion.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
04-01-2021, 08:30 AM | #8 |
Drives: Camaro 2021 ZL1 6 speed ragtop Join Date: Apr 2020
What do you mean “ soon tuning will be done away with”? Please explain
04-01-2021, 08:36 AM | #9 |
He's being a little dramatic but to answer your question it's getting harder to crack these new ecus and with the push for electric/epa restrictions some people think tuning is on its way out.
04-01-2021, 08:38 AM | #10 |
Last I knew, you currently cant tune 2021?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
04-01-2021, 08:43 AM | #11 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
The Magnuson Act says they have to prove that the modified part caused the failure so there may be some gray area depending on the problem but don't expect much. Depending on the dealer they may not go right to the ecu on an otherwise stock vehicle and you might get lucky, never know. But a major powertrain failure they'll definitely look so you need to be prepared for the worst or don't do it.
My dealer has covered the a8 shudder issue, a broken afm valve, and a noisy rear end knowing full well I'm modded. But if my engine pops I'm not even going there.
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
04-01-2021, 10:33 AM | #12 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
And don’t believe people who tell you it’s possible to fool the dealer by just flashing back to stock.
The tool the dealer uses can see flash counts on the ECU. There is also a checksum that changes every time the ECU is written.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
04-01-2021, 10:44 AM | #13 |
Mat is correct that you can't fool the dealer. You cannot get too complacent when dealing with mod friendly dealers either. If you scatter the motor, GM has to approve the replacement and you can bet that they will want to see the flash count.
Baby Blue
04-01-2021, 11:06 AM | #14 |
Yes tuning will void your warranty but if you’re not concerned about losing it, then tune away!
