01-22-2021, 04:52 PM | #1 |
Drives: Camaro ZL1 Join Date: May 2020
Where to place jack on rear of car
In my photo, circled in red. Is that where I can place the jack to lift car up. I want to lift rear end so I can swap drag radials with stock wheels. I got a headache from searching google for an answer and don’t want to mess things up.
01-22-2021, 04:55 PM | #2 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
No, jack it up on the black rear cross member (with the white peeling sticker). Make sure you don't clip the ears on the diff module behind the cross member.
01-22-2021, 06:44 PM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I jacked mine up there but used a thick piece of rubber as the point of contact. I then put jack stands on each side, since I have the mag pucks, and then rested it on those.
A small 2x4, cut to fit in the area, should work too. |
01-22-2021, 06:53 PM | #4 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
What about the front side? Where to Jack it up high enough to fit jack stands
01-22-2021, 07:09 PM | #5 | |
https://www.camaro6.com/forums/showthread.php?t=452280 |
01-23-2021, 09:47 AM | #6 | |
ZL1 Believer
01-23-2021, 01:37 PM | #7 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
There are so many things under these cars that is kinda fragile. Plus I hate bending over anyway.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
01-23-2021, 01:53 PM | #8 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I can't wait to have a garage big enough to install a lift !!
OP, if you're like me and don't have the ability to have a lift in your garage yet, look into quick jacks. You'll never have to worry about were to place jack stands ever again.
2016 Challenger Hellcat /B5 blue/Sepia interior/Brass Monkey Wheels/
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
01-23-2021, 04:52 PM | #9 |
01-23-2021, 04:53 PM | #10 |
I just checked out their website briefly. Looks interesting, where to they grab on the bottom. Im assuming it doesn't destroy the side skirts.
01-23-2021, 09:03 PM | #11 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
That's a 'parking lift' not a working lift. Gives you two parking spaces.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-23-2021, 09:14 PM | #12 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
This is great I was about to start a thread asking to see if the quick jack should extend forward like the manual says. Or I read that it should extend backwards so the weight of the front counter balances.
01-23-2021, 09:33 PM | #13 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
You can easily change tires on a 4 post lift. I do it all the time on mine. I have a Jack that slides down the center track of the lift and has arms that are adjustable inside to outside. I can lift either the whole front end or the whole rear end off the car off the wheel paths. I also have a Jack tray that I can use and raise all 4 wheels off the lift at the same time.
It’s not just an extra parking space. |
01-24-2021, 10:09 AM | #14 |
Drives: 2019 ZL1 1LE Camaro A10 Join Date: Jun 2019
I took some roll cage tubing and welded it up. It sits about 3/4’s of an inch below the side skirt. On my ZLE when you use the front one it lifts front and rear off the ground. It’s been working really well for me, much easier when putting the track tires on.
2019 ZL1 1LE
2016 Mustang GT 2014 GT 500 2012 GT 500 2010 Mustang Spec Iron 2003 New Edge w/Coyote Now running in America Iron 2000 New Edge w/ Coyote 2004 Corvette 2002 Corvette |
