01-10-2021, 12:21 AM | #1 |
Drives: 2019 White ZLE Join Date: Aug 2019
no garage door open in 19 ZLE but one in 20 corvette
Hi, has any one looked into putting a garage door opener in the 2019 ZL1 1LE ?
the new 2020 corvette has one in the drivers visor, it seems like one could be added to the 19 camaro? has anyone tried installing a 20 corvette visor with garage door opener in the camaro? |
01-10-2021, 01:22 AM | #2 |
Drives: Current driver AMC emlin X 5ltr. Join Date: May 2011
Alot of garage doors can be opened with an app on your phone. If it's wifi enabled
01-10-2021, 04:26 AM | #3 |
i havent been able to figure it out, does the garage door work on wifi?
01-10-2021, 07:29 AM | #4 |
Drives: 2023 SS 1LE Join Date: Mar 2020
19 ZLE doesn’t have the home-link? Did they change that in 19MY? My 18 ZLE has one. I would imagine you could put the same one I have in the 18MY into the 19MY.
01-10-2021, 07:55 AM | #5 |
ALWAYS-N-BOOST
2021 Does NOT have home link either
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
01-10-2021, 08:40 AM | #6 | |
01-10-2021, 08:42 AM | #7 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
My 2018 ZL1 1LE had it. My 2019 ZL1 1LE does not. Dumbest thing ever.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
01-10-2021, 08:43 AM | #8 | |
Thank you Al Oppenheiser!
Yes. Their excuse was that there was not enough "room" in the overhead console after they added the new display-mirror. But as we can clearly see from the corvette visor (which has existed for about a decade or longer) this story from gm* is BS. The Camaro unit used up through '18 is a one-piece model, whereas the corvette has the buttons in the visor but the electronics in a separate module. This two-piece unit could have easily been installed into the Camaro. *new logo, ya know |
01-10-2021, 08:46 AM | #9 |
I double sided taped my garage door remote to the upper part by rear view mirror on left side. Not visible and easy to use.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
01-10-2021, 09:27 AM | #10 | |
01-10-2021, 09:52 AM | #11 | |
S1N1STR
Check with gen5diy and see if they have a harness to retrofit an 18 into a 19..? Sent from my iPhone using Tapatalk Pro |
01-10-2021, 10:04 AM | #12 |
Drives: SWXXZL1 Join Date: Jul 2020
I used VELCRO on the back of the garage remote. It easily attaches to the carpet beneath the console, next to the drivers knee.
Or, on the drivers side headliner above the visor there is a shallow indentation which will accept a remote. Use VELCRO there leaving the button for your opener exposed so you don't even have to pull the visor down. Don't need to over think this.
"Joe" does a hilarious impression of a slinky toy on stairs.
01-10-2021, 11:57 AM | #13 | |
Alternatively, you can try and work it into your current visor. The problem there is the vanity mirror & lights that may not allow enough space, the wireup, plus you'd need to come up with a clean way to tuck the wires once you hooked the controller up. Sorry I can't be more helpful, I haven't done anything around the visor yet and the car is in storage, so I can't check it. The overhead console can definitely "offer" +12V and ground for a homelink remote, but that's pretty much all I know. The visor might could also be tapped for power. This is your opportunity for a unique, innovative approach
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 01-10-2021 at 01:21 PM. |
01-10-2021, 12:20 PM | #14 | |
Drives: 2018 ZLE Join Date: Jul 2014
