12-27-2020, 04:53 PM | #1 |
Dyno Show Queen LOL
Supercharger trunk tank and chiller Install
First off is relocation of the modules in the trunk. The carpet removal is pretty straight forward so I will not go into that.
1. Unbolt the modules and unattach the harnesses 2. Install a stud into the upper brace hole on the drivers side rear qtr panel brace. Just bolts, washers, and flanged lock nuts is all thats needed to hold the module. (The larger module holes actually line up perfectly with the brace by placing the module at an angle however you may want to mount the module to sheet metal to secure the module better, then attach the panel w the module to the brace.) I just attached the module at an angle. 3. The passenger side is a pain in the ass because the wire harness has either the back up camera or the air bag sensors wires with the same harnessas as the fuse box. The idea is to route it with no cutting and no cables pulled to tight. (And to be able to ck or replace fuses) I found the best thing was to mount the fuse box with a L bracket made from scrap metal I had laying around to the brace on the 1/4 panel vs some people mounting on the angle of the wheel well tubs with self tappers The small box on the end of the cable with the fuse box will be mounted directly above the fuse box or upside down on the some bracing on the top of the trunk. Again studs will be used to mount components making them easy to R & R if need be. This is all done with no drilling no cabel cutting or self tappers. Next week I'll go over the trunk reservoir install ( pump install and hose routing)
12-28-2020, 08:27 AM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Dec 2017
thanks for the pics. i actually want to redo mine .
01-02-2021, 01:23 PM | #3 |
Drives: 2018 Camaro SS Join Date: Sep 2009
Nice work! I’m looking forward to the rest of the install
01-02-2021, 01:36 PM | #4 |
Dyno Show Queen LOL
Thanks guys I took a little detour and I'm adding some sound deadening mat first. I know it adds weight but my freaking exhaust is so loud I can't stand it any more hopefully it will knock down the Toyo noise aswell.
01-05-2021, 02:09 PM | #6 |
Dyno Show Queen LOL
Will do ill be back on the tank install this weekend
01-06-2021, 08:34 AM | #7 |
Petro-sexual
Cool stuff!!! Thanks for sharing. Following...
01-06-2021, 07:59 PM | #8 |
Drives: Turbo 6.2 Join Date: Feb 2019
Cool thread. Keep it going
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
01-08-2021, 11:57 AM | #9 |
Drives: Camaro ZL1 Join Date: Nov 2020
Could you provide the sizes/lengths/thread pitch of the bolts/studs you used to relocate the components? I'm going to to start on the relocation this weekend as well.
Thanks. |
01-09-2021, 08:02 AM | #10 | |
Initially Wow this sounds amazing, you should buy it, Tires are awesome I don't mind the noise. Months Later, I want to jump out of my car at 70 mph LOL Moral of the story, have faith in our engineers that designed our cars. Ted.
www.jannettyracing.com
01-09-2021, 11:07 AM | #11 | |
Dyno Show Queen LOL
M8 x 40 for module upside down and the module on the bracket all M6s x 30
01-09-2021, 11:35 AM | #12 |
Dyno Show Queen LOL
I doubt I'll do much this weekend still trying to figure out bosses pathfinder taking up the lift. Keeps blowing the TCM fuse done fluid flush and new TCM, then TCM and valve body with solenoids. Must have a bad ECU or harness. U1000 code.
Good news is I got my grommets and tank in.. I had a custom tank with a intercooler brick inside it. I was going to just add ice and water over the brick vs having ice circulate and contaminate my brick in blower from minerals in the 🧊. So its for sale lol. I got a universal tank at summit for 219.00 w 5 off using the app. The PNR tank is 200 but I was worried the fitting going to the pump was mounted to high so the I went with the Rhodes Racing tank.
01-09-2021, 06:00 PM | #13 |
Is that tank going to fit under the trunk carpet? If not, are you planning on selling it?
01-09-2021, 08:28 PM | #14 |
Dyno Show Queen LOL
This tank?
Its for sale it measures 24x14x10. I didn't customize this one to fit under the carpet so I could put plenty of ice and water or dry ice even on top of the core. Has 2x 1 inch NPT and 1/2 npt drain. Has a bell or afco core can't remember what outlaw used. Has some water spots or stains from a laundry soap splashing on it not to bad could be cleaned I guess. I asked about a custom tank that fits under the carpet and it would of taken a 110.00 lid to guarantee no leakage. Plus I'm trying to keep the build cost down. a custom tank from Outlaw racetrack was 385 plus 90 to ship and the lid was another 110. WeaponX told me he wouldn't sale me a tank with out a pump. I all ready have the stewart reprogrammed pump. Wasn't about to pay 800. Plus my golf clubs don't even fit tank or not so its not a big deal about carpet. I'm gonna make it look as good as possible.
