Old 12-25-2020, 02:04 PM   #1
Silverado60
Silverado60's Avatar
Drives: 2010 camaro 2SS/RS M6
Ls3 timing chain tensioner vs dog bone
In the middle of my cam swap and have both in hand but can’t decide which one to use
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
Silverado60 is offline   Reply With Quote
Old 12-25-2020, 04:58 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
The dog bone...
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-25-2020, 06:32 PM   #3
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
LS2 style. The LS3 standard style tensioner is too prone to breakage with bigger cams
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 12-25-2020, 06:52 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
^^^Dog bone LS2 for sure. Do it now and never think about it again.
I have seen too many failures related to the LS3 tensioner to be comfortable to leave the stock unit in on a cammed engine. We even had a Camaro5 member post about his failure recently. I have seen a couple where the metal spring clip breaks loose and and get wedged between the upper gear and gouges the face of the block/gear. I also saw one get wedged between the face of the cam and upper gear, which was completely baffling as there shouldn't be any clearance there. But I guess at high rpm and banging any spinning parts, anything is possible. Last thing you want is that spring clip floating around your engine smacking into who knows what. Luckily most of the time they end up in the pan with some broken plastic pieces.
The only real downside I can see to the LS2 style is that it doesn't put any real tension on the chain like the LS3 style, so it will give the impression that it has slack in it. But it still prevents excessive slap.
InFiD3ViL is offline   Reply With Quote
Old 12-25-2020, 07:31 PM   #5
Neumatic
Drives: 2010 Camaro 2SS M6
LS2 dampener for sure. The LS3 tensioner is straight trash.
Neumatic is offline   Reply With Quote
Old 12-25-2020, 08:21 PM   #6
Silverado60
Thanks for the input guys!
I tend to agree with what you guys are saying. But I’ve also seen some talk of broken timing chains being the reason GM went with the Ls3 style.
Making it quieter for the Cadillac may have also been a reason
Old 12-25-2020, 08:39 PM   #7
Chris49066SS
Drives: 2010 SS L99
For a modded LS3/L99, you want the LS2 dampener. OEM planning and building is not the same as modded 5th Gen LS3 and L99s. You can look through hundreds of threads and read why the LS2 dampener is the one you want if you put a cam in. Good luck and happy modding!
Old 12-26-2020, 07:15 AM   #8
rdavis
Drives: 2012 SS
Do you have to remove the oil pump for the install? Looks pretty tight.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 12-26-2020, 07:33 AM   #9
Silverado60
I’m doing a melling pump and new timing set for a 3 bolt cam gear. Which is pretty much standard issue
But I’m pulling the timing cover today so I can look into that for you
Old 12-26-2020, 07:54 AM   #10
Silverado60
I believe what your saying is correct and the dog bone will go in.
The last thing I want is a broken tensioner
Thanks for the reassurance
Old 12-26-2020, 09:42 AM   #11
Thunder70
Thunder70's Avatar
Drives: 2010 ss camaro
Ls2 one for sure
Thunder70 is offline   Reply With Quote
Old 12-26-2020, 10:59 AM   #12
rdavis
Drives: 2012 SS
Thank you , very interested if you can swap it out w/o disturbing the oil pump. When I did my cam swap my tensioner was in perfect shape so I left it alone. Next time I am in it I would like to install the LS2 damper.
Old 12-26-2020, 01:36 PM   #13
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Oil pump must be removed to replace the tensioner. The bolts hit the back of the pump.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 12-26-2020, 02:16 PM   #14
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
What did the cam manufacturer installer/tuner recommend ? How radical is the cam ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
