11-13-2020, 08:53 PM | #1 |
Drives: 2015 1SS/RS M6 Join Date: Oct 2010
Help! Weird happenings to my baby!
So my 2015 SS is giving me some noises. One is up in the front end. Only happens at street speeds or slower. It’s a squeak/scrape when I turn or brake at low speeds. It also happens when I’m not braking. The other sound is when I slow down there’s a free spinning type of sound coming from the transmission/driveshaft? Went for my oil change but the people there couldn’t find anything visually wrong when they had it on the lift. They heard it but no go. Now it’s going off to the stealership on Tuesday. Just wondering if anyone recognizes these issues or has any ideas. It runs and drives perfectly. Gears shift as they should. Engine as well.
11-14-2020, 12:26 AM | #2 |
Maybe something with your brakes or wheel hubs/bearings. Sounds like a gremlins in your engine. Please post when you find the problem.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
11-14-2020, 08:28 AM | #3 |
Do you have caliper covers on? Mine use to scrape and squeal on low speed turns when I had them.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
11-15-2020, 07:54 PM | #4 |
Drives: 2014 1ss camaro Join Date: Jul 2017
when I first bought mine I had a small rock get between the shield and rotor and made a terrible sound. the rock wore down and I got it out
