10-20-2020, 05:35 PM | #1 |
Drives: 2013 camaro SS Join Date: Aug 2019
Parts found I forgot about 😂
I just found a set of BMR adjustable toe rods that I completely forgot about in my shop. Am I the only one that buys stuff and completely forgets that they had them. I was about to buy a set lol!!
10-20-2020, 05:36 PM | #2 |
I wish they were red
10-20-2020, 07:40 PM | #3 |
Drives: Never just fly under the radar Join Date: Jul 2015
Nope, occasionally I end up with duplicate tools that exact way.
Old Skool |
10-20-2020, 08:01 PM | #4 |
Lol
10-20-2020, 08:22 PM | #5 |
Lol, damn dude, that's an awesome find. At this point it's almost like getting them free!
10-20-2020, 10:26 PM | #6 |
Drives: 2015 Camaro Join Date: Aug 2018
It's called you have way too much money. I can solve this if you send me some of this extra cash that you seem to have. Trust me, it will help mitigate the problem nicely. Let me know....
10-20-2020, 11:14 PM | #7 |
Drives: 2014 1ss camaro Join Date: Jul 2017
I do that with tools. ahhh the 70's were good to me.
10-21-2020, 09:00 AM | #8 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
I have brake pads and a Hurst shifter that have been sitting around for over a year, both are going to be installed this weekend, the only way to stop procrastinating is to make plans to do it, I'm throwing $100 to a buddy to use his garage!
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
10-21-2020, 02:21 PM | #9 |
I need lower control arms
02-01-2021, 11:47 PM | #10 |
Drives: 2012 Camaro Lt/Rs Join Date: Jan 2021
Still got these?
02-02-2021, 06:45 AM | #11 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I had a battery issue talked about in another thread and bought a battery to swap. Its been on my shelf for 6mo. LoL oem one still working.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
02-02-2021, 09:47 AM | #12 |
Hey Domangue, look around and see if you have any BMR rear LCA'S, if you do I can use them so they aren't sitting there. lol. No seriously, I too have had stuff just sitting around waiting to be installed that for some reason, out of sight, out of mind, I forgot about them.
02-02-2021, 11:11 AM | #13 |
Absolutely, I've done it quite a few times with varies different parts. Fittings and hose ends is the most common, I have a speed bleeder for my clutch floating around somewhere in the shop, I have 3 different sets of differential bushings because why not, theres a ARP crankbolt I forgot I had until just after I bought and installed one in my new engine, the list really just keeps going.
