10-07-2020, 08:39 AM | #1 |
Drives: 2019 Chevrolet Camaro Join Date: Sep 2019
Competitive Driving Mode
Guys:
Clear something up for me. I'll be taking the car to the track soon and want to take everything off (TC, Stabilitrak). The manual says to take those off, press and hold the TCS button. Later in the manual, it says to take those off, but to be in competitive driving mode, to hit the TCS button twice. So are there two different modes? TC and Stabilitrak off with no competitive driving mode and TC and Stabilitrak off with competitive driving mode? Thank you Crush |
10-07-2020, 08:47 AM | #2 |
If you hold TCS for 5 seconds it will turn off pretty much all nannies. If you use competitive mode stabilitrak will intervene if the car gets loose side to side.
2016 NFG 1SS A8
10-07-2020, 10:05 AM | #3 |
Drives: 2016 2SS Join Date: Apr 2020
I like competitive mode. It gives enough to have some fun and kick the tail out some without getting to the point of no return. I usually only turn everything off if I'm in an open area.
10-07-2020, 10:08 AM | #4 |
i put my car into track mode and then press the esc button twice and it puts it into comp mode it limites the abs and traction control and esc but doesnt turn everything off
10-07-2020, 10:40 AM | #5 |
So, the consensus is holding the TC button for about 5-10 seconds to shut everything off
The manual is slightly confusing.. Thanks |
10-07-2020, 11:03 AM | #6 |
correct are you road racing or drag racing?
10-08-2020, 02:22 PM | #7 |
drag racing
b |
10-08-2020, 02:41 PM | #8 |
Turn it all off then.
2016 NFG 1SS A8
10-08-2020, 03:33 PM | #9 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Huh, mine goes into competitive mode when I floor it.
10-08-2020, 03:40 PM | #10 |
Drives: 2019 SS A10 Join Date: Mar 2015
Competitive mode is different from performance shift active, which kicks in at 40 mph when you floor it or quickly push the pedal all the way down and let go. It downshifts and holds the gear. Also has to be in sport or track.
Black 2019 SS A10, MBRP Exhuast, Soler performance Ported Throttlebody, Cold Air Inductions CAI, BMR equipped, Stance SFO7 on nitto NT555G2 tires, Limited Edition White Racing Seats, ZL1 1LE Splitter, Carbon Sideskirts, Gorilla Splitters areo kit, Next Gen Speed Diffuser, JWmotorsports LED side markers
10-08-2020, 04:19 PM | #11 |
The screen displays “Competive Mode Activated” or something like that when I get on it hard & does just what you said. Otherwise I have the selective modes through the TC button (Wet, Dry, Track1, etc)
10-08-2020, 06:12 PM | #12 | |
Drives: like an old lady Join Date: Jun 2012
the car will do mustang week things from second gear @ 50 in sport mode this time of year.
2016+ camaro: everyone’s first car
10-09-2020, 08:18 AM | #13 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I don't believe this is correct. Stabilitrak Competitive Mode (double-tap on mode switch in Sport or Track--not available in Tour or Snow/Ice). Will result in turning off (completely) Traction Control and reducing the amount of Stabilitrak. Both icons will illuminate in the dash. As mentioned above, this is a separate feature from "Performance Shift Active" which will appear in the DIC upon rapid acceleration (had not heard about the 40 mph threshold before--will need to check that out!).
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
10-10-2020, 07:27 AM | #14 | |
my m6 bolt on/ethanol car - flooring it in 2nd gear @ 50 tour - tcs light on solid = some controllable tire spin while the stabilitrak light flashes. the light will continue to flash pretty much all the way through 2nd and part of 3rd sport competitive - both lights on solid. floor the car @ 50 in 2nd and it immediately snaps, changes lanes, and tries to kill me. both lights stay solid and stabilitrak does not flash there is a very noticeable difference in how the car behaves. this is basically any temp under 75*. i don't floor it if it's under 55*
