09-04-2020, 07:46 AM | #1 |
Drives: 2015 Black rs/ss/1le Join Date: Apr 2018
Thud in the back normal?
I installed the z28 suspension kit several weeks back and I have a question for you guys.
I know the suspension is tight and driving over roads with a lot of patches can be fun. But it is normal to occasionally hear/feel a thud coming from the back going over a certain type of bump? It’s not a real jarring thud but it is pronounced. It’s hard to pinpoint exactly what type of bump causes this thud and it doesn’t happen all the time. It happens when going slower maybe under 30-40mph(?) and only on rough roads. I can’t seem to duplicate the conditions when this happens and it’s somewhat rare when it happens. The rear end is as tight as the day I installed the suspension. I also did a track day and it performed without any issues. I checked all bolts and everything seemed fine. Going over driveway curbs, backing out the driveway is also fine. I have solid cradle bushings installed and suspension bushings were timed if that matters to anyone. Thanks! |
09-04-2020, 07:53 AM | #2 | |
Drives: '15 Z/28 Join Date: Jun 2016
The Z/28 does not have any thuds on a correct car. There are pops and associated noises from our Torsen differentials, however, I don't think this would apply to you unless you've also installed the mechanical diff. |
09-04-2020, 09:14 AM | #3 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
Normally its fine, but if you were to hit a pothole, that'd do it... Or if you bought used, perhaps you got a bad component.
09-04-2020, 09:54 AM | #4 |
09-04-2020, 09:56 AM | #5 |
09-04-2020, 10:21 AM | #6 |
Then, and believe me with no disrespect meant, sounds like something is just not installed correctly or potentially not tightened properly. I can only relay that there are zero thuds of any kind from the back of my Z/28 and this includes some hard humps and bumps encountered on race tracks, etc.
09-04-2020, 11:13 AM | #7 | |
09-04-2020, 11:40 AM | #8 | |
These Z28’s are solid as mentioned. |
09-04-2020, 01:17 PM | #9 |
Could it be something else loose in the rearend? Spare tire, jack, battery, etc. I just hate sounds that aren’t suppose to be.
I feel your frustration |
09-04-2020, 04:55 PM | #10 | |
I really appreciate all your help. Thanks! |
09-04-2020, 07:18 PM | #11 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
I thought some people reported an ‘oil can’ noise? I don’t have it in mine, only noises for me are some clicks and pops for the rear end.
09-05-2020, 02:19 PM | #12 |
Drives: 2015 Z28 (sold) Join Date: Jul 2020
Is it the LSD?
09-05-2020, 09:50 PM | #13 | |
Drives: 2015 Camaro Z/28 #968 Silver Ice M Join Date: May 2019
My Honda CRV has the same issue. Got brand new struts with coils installed and it makes small thud x 3 noises when going over white line dots and other uneven roads. On a free way it drives smooth with no noises. On regular road it drives smooth with no noises. Only when going over bumps or uneven roads. Something is off. Never had that issue with my old struts except it was bad and waved up and down a lot going over uneven roads. Now the new struts drives tight, but small thud x 3 sounds is making me mad. Took it back to the dealer and they checked everything all good. I guess it's just the nature of the beast. Put something or replace parts that's not original, and you're going to get something off. Good luck and hope you find it.
Current Cars:
2008 Honda CRV 2.0L 2015 Chevy Z/28 7.0L 2016 Chevy Tahoe 5.3L Past Cars: 1976 Chevy Malibu Classic 5.7L 1985 Chevy 2DR 4x4 Blazer 5.7L 1989 Chevy IROC-Z 5.7L 1995 Chevy 2DR 4x4 Tahoe 5.7L 2005 Chevy 4DR Tahoe 5.3L |
10-02-2020, 03:47 PM | #14 |
Not to hijack the thread but I also have a popping/clicking sound when I make turns at very low speed ie right turn from a stop sign. 100% stock ‘15 Z/28. I heard it may be the diff? Anyone else experience that?
