06-26-2020, 03:04 PM | #1 |
Drives: 2018 Camaro ZL1 M6 Join Date: Jul 2017
Metallic Flakes in oil
Just checked my oil after the car was sitting for a few days and noticed what appeared to be metallic flakes after wiping off the dip stick.
Car is an early 2018 and I filled it with Mobile 1 0W40 ESP dexos 2 last July, but it was garaged from last DEC to basically last weekend so the oil only has probably 2000 miles on it. Anyone else see this? Is this indicative of the oil pump failing? Had a couple more particles in the second wipe from the left that were smaller so you can't see them in the picture. After the second check I wasn't getting any particles.
3000-9/18/2017 Received-12/1/2017 |
06-26-2020, 03:12 PM | #2 |
Are you sure you started with a clean towel/rag?
06-26-2020, 03:23 PM | #3 |
Good point. It may just be the paper towel I used, but it's still oddly coincidental the particles are only where I wiped. I just checked and the paper towel I used was bunched up with another paper towel that I used for god knows what and it also appears to have some smaller metallic particles on it.
Hopefully just a false alarm. Either way I have a magnetic drain plug and I'm getting the oil changed in a couple of weeks so I'll have them check it out. Thanks for stating the obvious.
06-26-2020, 03:24 PM | #4 |
Drives: 2017 ZL1 Camaro Join Date: May 2018
I know you well past the break in period but aluminum colored flakes are common during that period. I checked the filter at roughly 500 miles on my ZL1, 2018 Silverado, and 2018 Acadia, all 3 had a large amount of aluminum colored metal flakes in the filter when it was cut apart and were roughly about the size of the one in your picture. In all 3 vehicles these flakes were pretty much gone after the 3rd oil change at 1000 miles and my filter was very clean when cut apart. My point is we have a cast aluminum block and cast aluminum headed engine. Tiny pieces may come loose over the life of an engine, less likely as time goes on, like I mentioned I saw alot of this during the first 1000 miles.
If you indeed have an engine issue that is causing metal flakes to appear you need to cut apart your filter and inspect the filter pleats, its very easy to do and give you a really good idea of whats going on inside your engine. Any engine condition that is causing metal flakes will typically produce a lot of them and they tend to stay in the filter. Check your filter, if it's clean change oil and filter and check the filter again at the next oil change. Here is the tool I use, it works really good. You can also use a tin snips but they are a pain in the butt IMO. Do not use a hack saw to cut open your filter (you will freak out when you see it full of metal shavings from the hack saw) https://www.summitracing.com/parts/sum-900511
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle |
06-26-2020, 03:26 PM | #5 |
Also, just an FYI if the particulates are aluminum they will not stick to the magnetic drain plug.
06-26-2020, 03:34 PM | #6 |
I always cut mine open after every oil change. I've seen those flakes before, sometimes not a good sign. I've broken a couple Lt1s over the last few years and its a gut wrenching feeling when you cut one open and see the shit I've seen.
06-26-2020, 03:44 PM | #7 | |
Either way, thanks for the info, I did just run a magnet over it and it's not picking it up so it's most likely aluminum from the engine like you mentioned. I'll keep an eye on it.
06-26-2020, 04:15 PM | #8 |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
Send a oil sample off for analysis. At least you will either sleep better or start saving money for a build.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
06-26-2020, 05:23 PM | #9 |
Drives: 2019 Summit White ZL1 Join Date: Mar 2020
Agreed.....only about 20 bucks....and you will know.
06-26-2020, 06:15 PM | #10 |
I don’t think you should worry at this point, just send your oil sample and get an oil analysis done.��
06-26-2020, 06:39 PM | #11 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
^^^This^^^
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
06-29-2020, 07:34 AM | #12 |
Where's a good place to send it for analysis? How much do they need?
06-29-2020, 08:32 AM | #13 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
07-27-2020, 09:04 AM | #14 |
Status Update:
I had the oil analyzed by Blackstone labs and everything came back fine. I've continued to periodically check the oil and I still find these microscopic, possibly aluminum particles but I guess that's just normal. I tracked the car last Tuesday so if my oil pump was failing I'd suspect I would have had an issue back then.
