05-25-2020, 04:39 PM | #1 |
Silver Shark
Drives: 2014 2SS GM Npp 6 speed manual Join Date: Nov 2014
430rwhp!!!#???
My current set up on my 2014 Camaro ss Ls3 Kooks long tube headers, Kooks hfc, Cai intake and scoop. My question is. How many crank HP is pushing out with 430rwhp dynoed at the wheels. Thank you all for your response. Just curious. .
Silver Shark20*10,20*11 Z28 black gloss replica wheels, 285/305 tires, BMR Strut brace,Kooks lt headers/hfc, CAI cold air intake/air scoop
05-25-2020, 04:48 PM | #2 |
Calculated at the generally accepted 15% for a manual, around 495 crank.
05-25-2020, 07:58 PM | #3 |
Started#gottalovethatblue
Why do you care about crank hp? It's just an estimate where wheel horsepower is an actual measured number.
05-25-2020, 08:30 PM | #4 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Curiosity kills the cat
05-25-2020, 11:05 PM | #5 |
Drives: 2013 1LS Join Date: Apr 2019
You can always get a good estimate by dividing WHP by .8 if it's an auto or by .85 if it's a manual.
05-26-2020, 12:18 AM | #6 |
I knew my estimate was off by a bit.
05-26-2020, 08:54 AM | #7 |
Drives: 2011 Camaro SS Join Date: Jul 2019
430 whp seems a bit high.
05-27-2020, 09:45 AM | #8 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Not too crazy for a 14-15 LS3, I hit 425 with bolt ons.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
05-27-2020, 11:53 AM | #9 |
I know a guy who hit 460ish rwhp with two different stock cam and heads LS3. 430 is pretty normal
2010 2SS/RS
05-27-2020, 12:48 PM | #10 |
I was a little over 430 with the same mods and no cats before I had my cam and other mods.
05-27-2020, 04:36 PM | #11 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
1/.85 = 1.1765 (rounded up)
1.1765 x 430rwhp ... so appx 506hp The increase due to the increase in air/oxygen-flow and fuel. Is that right? Because now people are going to say they have a 500+ horsepower car lol Mine's settled at 426rwhp for now with bolt-ons and a tune... |
05-27-2020, 07:19 PM | #12 |
Drives: 2013 camaro 2ss 1le Join Date: May 2020
well a 10 second glance at a handful of reported stock dynos, ls3+m6 averages around 370-375ish and l99+a6 averages around 325-330ish. so you can figure the loss factors as 12% for the m6 (426bhp÷375whp) and 18% for the a6 (400bhp÷330whp) with fair accuracy.
so you can assume to have roundabout 482bhp with a stick (430whp*1.12 aka 12%), without taking into account whatever error and variation your particular dyno will have. also 12% loss is insanely good, i dont know if gm underrated the ls3 by a few horses or the 6060 is just THAT efficient somehow.
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners |
05-27-2020, 07:20 PM | #13 |
Drives: 2010 Camaro 2SS Join Date: May 2016
Rwhp is only a number.On one dyno the same car could be at 370-380.
In my opinion they should only be used for comparison from before and after etc or if lots of people are using the same dyno you could compare your car to another with the exact same mods to see if you have any problems. Other then that they should be taken with a grain of salt. |
05-28-2020, 02:33 PM | #14 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
