05-19-2020, 08:06 AM | #1 |
Drives: 01 SS Camaro Join Date: Jan 2012
Stage 4 BTR cam for "daily driven" M6?
Im about to pull the trigger on a '13 ZL1 with a BTR Stage 4 cam and supporting mods (appropriate valve train, CAI, Kooks headers, 1000cc injectors, heat exchanger upgrade etc). Car will be a daily driver with a 50/50 mix of highway and city.
My concerns are the drivability and dare I say economy... I know we don't buy these cars to save money at the pump, but I don't think I could live with 10-12 mpg either. Also, I see Gen 5 ZL1's go for anywhere from high 20's to high 40's. I know that being a kinda special version of the Camaro, KBB is likely way off on its valuation. What should someone pay for a low mileage example of a ZL1? I don't really consider mods to be value adders, so Im not taking that into consideration. |
05-19-2020, 12:51 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
That screen name is familiar...
05-19-2020, 01:19 PM | #3 |
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam Join Date: Mar 2018
I have a TSP Stage 4 F35 cam in an M6 SS FBO. You will be in the 10-12 mpg range and that's if you're keeping your foot off the pedal.
05-19-2020, 06:58 PM | #4 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Even stock these cars don't get good gas mileage, so with mods (especially a cam) it can get worse depending on the tune. If you're even slightly worried about driveability and mpg and you've never driven a cammed car; you may not like it. You really need to test drive it. I have a baby cam in mine and it still puts down great power and drives great.
05-19-2020, 09:43 PM | #5 |
05-19-2020, 09:49 PM | #6 | |
05-19-2020, 09:58 PM | #7 |
^^^ True. I get better mpg now compared to stock when hwy cruising.
05-20-2020, 03:52 AM | #8 | |
Stage 3
More on my journal... |
05-20-2020, 08:54 AM | #9 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I agree. I get 16.5 mpg on mine driving back and forth to work daily on country backroads- mostly 35-55 mph, with a bunch of stoplights and stop signs.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-20-2020, 10:50 AM | #10 |
16.5 is more than I expected so that makes me happy! I’m not familiar with the guys who tuned it, so I’m going to have a new tune done at raceproven in Kentucky. I’ll try the stage 4 out for a while and if it’s not comfortable on the street I may go with a smaller cam.
Thanks for the replies guys!! |
05-20-2020, 12:56 PM | #11 |
Drives: ZL1 Join Date: Dec 2016
I get 22 mpg cruising on the interstate at 78 mph with a .646 lift cam, heads ported, cold air with 2.55 upper pulley and 9.55 lower, ARH 2 inch headers cat delete. Auto Trans. Much better than when it was stock.
05-20-2020, 02:12 PM | #12 | |
If driven with a light foot, any car with a really good tune should become more efficient, even with a ton of mods. They usually don't because they are so much more fun to drive fast! |
05-20-2020, 02:38 PM | #13 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
I barely get double digits mostly because my commute is mostly city streets. Plus I like to have fun in this car.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
