dave@hennessey
Old 04-23-2020, 06:55 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
3 inch all round or NO?
I know a fair amount of boosted owners keep the 2.5 setup. You guys think I should upgrade to 3” cat back with custom mufflers for 800$-ish for just keep the 2.5” w/ my NPP muffler mod setup?
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 04-23-2020, 08:25 PM   #2
Marotrent
Drives: 2011 Summit White Camaro SS
I'm interested in the response to this question. I just ordered a full exhaust system minus the mufflers from ARH. I have a set of NPP mufflers already but I was wondering how much would the car benefit from the 3 inch piping or is it just for show.
Marotrent is offline   Reply With Quote
Old 04-23-2020, 08:33 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
3" spintech here....
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 04-23-2020, 08:40 PM   #4
Marotrent
Think you got a HP/TQ increase from it?
Old 04-23-2020, 08:54 PM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
There are gains to be had but i don't think it's necessary until you are pushing over 750whp. But no i couldn't tell you unless i upgraded. I was talking to Ted about it and i don't remember the numbers he told me exactly. 102mm throttle body i know he said world be worth 15hp. I want to say 2"headers and 3" exhaust he said would gain me about the same.
Greenhornet2 is offline   Reply With Quote
Old 04-23-2020, 08:56 PM   #6
RupertPupkin
From previous threads I’ve read, and YouTube vids, there are benefits. However, to see the most result, you have to be pushing some good power. I’m going to be in the 750-800rwhp range.
I’m just curious to see why some guys here keep the 2.5 setup with their FI build.
I did see these.. https://www.speed-engineering.com/sh...s-1le-zl1.html
Not bad for 500$. I’ve had my fair share of bullet mufflers. Love the sound (depending on brand), didn’t mind the drone, but they did drone ALOT!!
730whp: 630Trq
Old 04-23-2020, 08:58 PM   #7
RupertPupkin
15 hp... not worth it in my book.
730whp: 630Trq
Old 04-23-2020, 09:13 PM   #8
Greenhornet2
At 750-800whp it may be more. There is a full 3" set up for like $300 on amazon.... i almost bought it.
Old 04-24-2020, 08:40 AM   #9
RupertPupkin
290$ + free shipping.
I would have to swap out to the quad exhaust tips, and maybe the muffler. Great price though.
730whp: 630Trq
Old 04-24-2020, 10:53 AM   #10
Axe55
Drives: 2012 Camaro SS
Upgrading the exhaust is my project for next year, I was thinking 1 7/8" LTs and a 3" exhaust. I wonder if the size of the LTs would impact your exhaust selection, if you have 1 7/8" headers go with 2.5" exhaust, or if you have 2" headers go with 3" exhaust. Would a 3" exhaust on 1 7/8" headers be a waste?
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 04-24-2020, 12:21 PM   #11
Bo White
Bo White's Avatar
https://www.camaro5.com/forums/showthread.php?t=400900
Old 04-24-2020, 12:32 PM   #12
RupertPupkin
Originally Posted by Bo White View Post
Thanks for the link.
Who tf said you gained 50 w/ 3”... it was in 1 of the old threads. What muffler did you have? I think that should be the limiting factor, if they’re restrictive.
730whp: 630Trq
Old 04-24-2020, 01:23 PM   #13
Bo White
Bo White's Avatar
https://www.camaro5.com/forums/showthread.php?t=323084
Old 04-24-2020, 04:01 PM   #14
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Agree here. I am running 3" corsa extreme with longtubes. Dont think its worth much of anything over the 2.5 until you are moving some serious air.
gunchamp is offline   Reply With Quote
