03-03-2020, 01:54 PM | #1 |
Drives: 2018 ZL1 Convertible Join Date: Nov 2011
Offset help please
Have a stock 2012 Camaro SS with factory 8" & 9" wheels with 35mm offset on fronts and 40mm offset on rears.
If I 'upgrade' to 1 inch wider wheels, 9" front and 10" rear with the same 35mm and 40mm offsets as factory, will the 1 inch additional width be spilt half under the car and half out toward the fender lip - or will the entire 1" additional width be all out toward the fender lip? I've confused myself trying to figure this out and need some help - THANKS! |
03-03-2020, 02:00 PM | #2 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Backspacing should tell you
GJDM |
03-03-2020, 02:10 PM | #3 |
03-03-2020, 02:33 PM | #4 | |
GJDM |
03-04-2020, 05:40 AM | #5 | |
Drives: '20 Corvette Stingray Join Date: Jul 2009
and I am sure the 10's would be fine as well.
03-04-2020, 05:46 AM | #6 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
On the front of my 2014 Camaro I am running ZL1 replica wheels that are 20"X10" wide with 35 MM offset. They are wrapped with 275/35/20 Continental Extreme Contact tires. ZERO issues.
03-05-2020, 05:56 PM | #7 |
03-06-2020, 05:12 PM | #8 |
376 cubic inches of fun
If the wheels are 1 inch wider and the offset is the same, then yes, there will be 1/2" less inner clearance and 1/2" more protrusion.
