Old 12-02-2019, 11:38 AM   #1
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
Sxren_Camaro'13's Avatar
Drives: '13 Mod Camaro LS
Camaro drinking oil
I think my camaro is burning oil what do you guys think i checked the dip and it was low...
Sxren_Camaro'13 is offline   Reply With Quote
Old 12-02-2019, 11:41 AM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
How many miles since you checked it last and or added oil?
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 12-02-2019, 11:45 AM   #3
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
No help but when I read the header I knew it was a 6. My '10 SS has never burnt a drop.
Bring it up to Full and drive it 500 miles and check again. Then you will know.
myold88 is offline   Reply With Quote
Old 12-02-2019, 11:52 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Well you need to fill it to the correct level. Check and verify there are no leaks. drive it and check every 500 or 1000 miles and see if it gets low or how low. Acceptable oil consumption is less than 1 quart every 2k miles according to GM. If it I using more than that it is considered abnormal. Then its piston and ring time.
Greenhornet2 is offline   Reply With Quote
Old 12-02-2019, 12:01 PM   #5
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
75,000 its now 77,000
Old 12-02-2019, 01:04 PM   #6
xstuntman
Drives: 2012 Victory Red LFX
How low?
Any spotting on the driveway?
Catch can full?
You do your own oil changes vs an oil change place btw?
I wouldnt trust them to open my can of wd40. Also as engines age and get loose you sometimes need to get the next heavier weight oil or swap to the high mileage stuff too.
xstuntman is offline   Reply With Quote
Old 12-02-2019, 02:16 PM   #7
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Pull your engine cover and check out the valve covers. It's a pretty common LFX leak point.
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 12-02-2019, 02:50 PM   #8
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
Originally Posted by xstuntman View Post
How low?
Catch can full?
no,..id ont think so,no i do it at a authorized dealer, yeah i use synthetic and i can see oil residue on the engine cover on the right
Old 12-02-2019, 03:20 PM   #9
xstuntman
Originally Posted by Sxren_Camaro'13 View Post
no,..i can see oil residue on the engine cover on the right
Bingo.
You found one leak and there might be more than one.
Might need to look underneath to see if its running down one or both sides.
Old 12-03-2019, 05:58 AM   #10
Vec
Tejas Hillbilly
Vec's Avatar
Drives: 15 SS 2SS/RS LS3M6
Thumbs up
you do realize it's the new guy at the service dept and the part time employees that get the honor of all the crappy jobs like oil changes...right?
Navy Vet
Vec is offline   Reply With Quote
Old 12-03-2019, 07:12 AM   #11
MrChrisLS3
Drives: 2018 1SS M6
I admittedly don't know a whole lot about the Camaro V6. However, when I had a bad coil pack on my '06 Cadillac, and changed the plugs, I found oil in the spark plug channel. I called my brother, a shop foreman at Caddy dealership, and he said it is not uncommon for the o-ring between the cover and the head to fail.
MrChrisLS3 is offline   Reply With Quote
Old 12-03-2019, 03:14 PM   #12
mikeman
Drives: 2015 Camaro
It shouldn't be burning oil at only 77k miles. I'd take the cover off and see if you have any leaks. If not, maybe the oil change guy didn't fill it up all the way.
mikeman is offline   Reply With Quote
Old 12-03-2019, 03:47 PM   #13
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
maybe
Old 12-03-2019, 06:25 PM   #14
redcoats1976
i check mine about an hour after getting home from the oil change.so far its always been on the top line,but i think my dealer is better than most of them.
