Old 11-18-2019, 08:49 PM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
2 step for agp tt kit
Which 2 step are you guys using? My th400 will soon be back with a transbrake. I've hear of people using the lnc2000 or the msd. Which one is better or is there a difference?
camarosspower is offline   Reply With Quote
Old 11-19-2019, 09:30 PM   #2
AGP Turbo
Drives: All things Turbocharged
The LNC-2000 is perfect. No idea about the MSD, might be fine.
AGP Turbo is offline   Reply With Quote
Old 11-20-2019, 01:13 AM   #3
Slickcas
Drives: 12' 2SS/RS LS3 IBM
I use the MSD with my Vortech. Works very well. By far the easiest install. And set up. But it just interrupts the coil packs. Will build enough boost for 90% of people running turbos. Most turbo setup will be fine with it.
But the LNC-2000 has the ability to build more boost and more control.
Slickcas is offline   Reply With Quote
Old 11-20-2019, 10:55 AM   #4
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
LNC 2000 works best. I have had several buddies with bad experiences with their MSD 2 step.
graf101 is offline   Reply With Quote
Old 11-25-2019, 07:59 AM   #5
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Another Lingenfelter LNC 2000 fan here
stratman2SSRS is offline   Reply With Quote
Old 12-02-2019, 10:47 PM   #6
camarosspower
Thanks guys. I got the lnc2000 in today
Old 12-17-2019, 08:59 AM   #7
JackLS1R1
Drives: 10 SS A6 Huron TT
What is the best way to hook these up to work on Auto 6l80 cars?
JackLS1R1 is offline   Reply With Quote
Old 12-17-2019, 12:27 PM   #8
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I don’t know about for turbo cars but personally I have mine wired first to an on off switch, then to my brake pedal. So I have to first toggle the switch to on, then my brake lights have to be on for the 2 step to engage. That way it turns off right when I let off the brake for launches
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 12-17-2019, 04:08 PM   #9
NABeastRR
NABeastRR's Avatar
Drives: Camaro
That's how I ran mine but I have MSD with no issues so far.
15 Camaro 2SS/RS
13.3@106 100% stock
12.0@114 VR-DRX/RCR manifold/BW stg2 TB/2"ARH w cats/3"Corsa extreme/Fasterproms tune/MT Street R
AGP TT build in progress
NABeastRR is offline   Reply With Quote
Old 12-18-2019, 07:18 AM   #10
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
Did same the thing but on my ebrake.
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
