09-30-2019, 07:11 AM | #1 |
Drives: ZL1 Join Date: Jan 2019
19 inch wheels for the ZL1 A10
Hello everyone!
Thinking of getting a 19 inch wheels for the Zl1 to be used on track days. Currently I am on the stock 20 inch with P4S which is a very good daily use tire. Anyone did a similar successful setup? that includes the rims too. |
10-02-2019, 03:18 PM | #2 |
Drives: 2018 ZL1 Convertible Join Date: Oct 2018
not a single helpful reply on this thread? im guessing because this is searchable however ive have the same question for some time and havent taken the time to dig through all the posts.
10-02-2019, 04:38 PM | #3 |
Use stock ZLE 19" wheels with a 5mm spacer up front. Otherwise there are a million choices for 19".
10-03-2019, 06:13 AM | #4 |
Drives: Camaro ZL1 A10, F-Type R, RR Sport Join Date: Jul 2016
10-03-2019, 08:01 AM | #5 |
There is a tiny bit of poke, but have to do that in order to clear the strut if you don't do a custom offset.
I'm finally, finally getting my Apex ARC-8's that were part of their group buy back in March or April. They are in the ZLE specs. I did that because I'm fine with a small spacer and the price was good for a lighter wheel, but still durable. I'm mounting up the 19" sized regular SC3's, again the ZLE specs f/r and will be running the combination in two weeks. Will post my feedback. I've run the stock 20" 's a few times and was very impressed with the grip and wear, so look forward to the new wheel set.
2018 ZL1 - Garnet Red, NO Sunroof, A10, PDR, Carbon hood insert = Perfect
10-03-2019, 11:28 AM | #6 |
thanks for the info.
10-03-2019, 03:35 PM | #7 |
Drives: 2019 ZL1 Join Date: Aug 2018
I run 19x11 square for autox with 305/30/19 RE71R tires. ET11 front after spacers and ET43 rear. Before I did the camber plates, to run these with -2.5 front camber I had to grind down the knuckes on the MRC front struts otherwise there would be contact.
10-03-2019, 04:42 PM | #8 |
only 5mm...not noticeable or weird looking
10-03-2019, 04:55 PM | #9 |
Not bad...
10-04-2019, 08:28 AM | #10 | |
Drives: 2017 ZL1 6MT Join Date: Dec 2018
10-04-2019, 11:00 AM | #11 |
10-12-2019, 03:05 AM | #12 |
10-12-2019, 06:00 AM | #13 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
FRONT 19x11" ET11 Anthracite APEX ARC-8
REAR 19x11" ET43 Anthracite APEX ARC-8 TIRES Bridgestone RE71R 305-30-19 1. No spacers in front, but limited to -2.0 front camber.
10-12-2019, 06:11 AM | #14 |
Stock camber is OK clearance. -2.0° without the spacer, it is tight. You could grind the tab on the strut if necessary. The 5mm spacer was the easy way out.
