09-21-2019, 10:10 PM | #1 |
Drives: 2011 Camaro SS Join Date: Feb 2017
Drag Radial Storage
How are you storing your drag radials for off season? Should you air them up to max psi? Lean them up against garage wall or lay them on floor stacked on top of each other? Put on blocks to keep off floor?
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
09-21-2019, 10:40 PM | #2 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
Best way is to keep them in trash bags in the house, avoid concrete, uv rays and extreme temps, normal psi.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
09-22-2019, 09:13 AM | #3 |
Evil Genius of Chevrolet
Mine are at 20psi. Inside the house. Lay flat on top of each other.
Don't let them go below freezing temps.
09-22-2019, 09:54 AM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Away from sun, dries them out.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
09-22-2019, 10:25 AM | #5 |
Use them up in one season.
