09-10-2019, 07:52 PM | #1 |
Drives: 2012 ls3 Join Date: Feb 2014
ABS Light with Traction Control Light
Well just got my gears changed out to 410s and now ABS light and Traction Control light is on.. And when that lights on it's hard to crank like the battery is drained.. I guess I'm gonna have to take it to dealer. The shop that did the work says the light was on but I say that's horse s**t it wasnt on. Any suggestions before I go the dealer route??
09-10-2019, 08:22 PM | #2 |
Drives: 2010 Camaro 2SS Join Date: Apr 2011
ABS Light
Hey Dino,
When I swapped the differential in my 2010 I damaged the ABS sensor connected to the wheel hub. it's a $13 part and an easy fix. Something to check. Good Luck, John |
09-10-2019, 09:07 PM | #3 |
Drives: 2011 Camaro SS Join Date: Feb 2017
https://www.camaro5.com/forums/showthread.php?t=501013 here’s what happened when I did diff swap
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
