08-21-2019, 09:48 AM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
rare difficulty engaging 2nd gear
A handful of times over the 6k miles I've driven my 2018 1LE, I've noticed that going into 2nd doesn't always work. The knob will stop. Then I engage the clutch and the engine revs without power going to wheels. Then if I try to slide the knob even further there is a slight grinding sound. Ideas?
08-21-2019, 10:02 AM | #2 |
Drives: 18 2SS 1LE, 20 Canyon Denali Join Date: Feb 2016
relatively common, and normally solved/reduced with a fluid change. popular ones on here are Royal Purple syncromax and redline d4. personally, i swapped to fresh factory fluid and it made a big difference as well. way cheaper and accomplished the same goal for me.
i've tried them all, wasn't impressed with d4. was impressed with syncromax but fresh oem did the job for me
Mike
Current Garage: 18' 2SS 1LE, Hyper Blue 23' GMC Canyon Denali Previously: 20' GMC Canyon Denali 16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss) 14' Ford Edge Sport 06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada |
08-21-2019, 10:39 AM | #3 |
Drives: Black 2018 SS 1LE Join Date: Oct 2017
You're not just hitting the skip shift "feature," are you?
08-21-2019, 05:01 PM | #4 | |
Car is one year old and still under warranty. Is this something they would change given the symptoms I'm reporting? |
08-21-2019, 05:23 PM | #5 |
Thank you Al Oppenheiser!
CPM asked once. I’ll ask again.
Did you install a skip shift eliminator? If not, then RTFM. |
08-21-2019, 07:42 PM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
My car does it when I'm shifting right above idle...last synchro doesn't quite allow it to click fully into gear.
Changing the fluid reduces the issue, but doesn't eliminate it. Interesting, I reported this to Chevrolet during a service visit and their response was the same as above..."Skip shift feature." Not quite in my case. No change to the situation after 15,000 miles.
08-21-2019, 08:04 PM | #7 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Skip shift is a possible cause.
I had issues with the first shift of the day into second gear, and second gear always felt a little notchy. Swapped out to the RP syncromax and the condition is all but gone. Wanted to try Motul ATF but picked up the RP locally.
'18 1SS 1LE Black, PDR
08-21-2019, 09:58 PM | #8 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2017
My 1LE is doing exaxtly the same thing, and the dealer told me it was the skip shift feature also :thumbdown. They changed the fluid with the factory one and it's better.
Next year i Will try Royal purple |
08-22-2019, 09:29 AM | #9 |
Drives: 2015 Z/28 #997 Gone 2019 SS 1LE Join Date: Nov 2015
I don't even notice the skip shift from 1st to 2nd. Then again, I hold 1st until 3-4000 before shifting unless I am gettin on it.
08-22-2019, 02:53 PM | #10 |
Drives: SS 1LE Join Date: Oct 2017
They are probably right too. Even when it isn't skip shift engaging, because of that stupid feature, you don't get into 2nd as often as you would normally. For that reason, 2nd probably doesn't wear/break in at the same rate as the others and gives you engagement issues. Last autocross, I had a ton of issues getting 2nd gear in during launches.
08-22-2019, 03:13 PM | #11 |
Drives: Camaro 1LE Join Date: May 2018
When I bought my 2015 last year I had this same issue. The last owner said he had the same issue as well and thought that the linkage needed adjusted. Keep in mind the skip shift feature was not engaged causing the problem. Well I ended up installing the slp skip shift eliminator only to disable the system with plans to check out the linkage. In doing so, it somehow addressed the 2nd gear issue and I haven't had a problem since....almost 1,000miles. Every shift into 2nd is effortless and consistent (almost seems to suck the shifter) into place now. Not sure if this would apply to your car but figured I'd just share.
08-22-2019, 03:16 PM | #12 |
I'd disagree on skip shift for mine. It feels like it gets stuck between the synchro and the gear, I let the clutch out and it pops out to neutral unless I pull it into gear and it grinds. This only occurs at idle speed/rpm. Obviously I can avoid that area...but it won't get better with time. It is pretty minor.
I understand the skip shift is just a solenoid - either blocks the lever movement or not. Mine has been deactivated... Most importantly, absolutely no issues at any other time especially under heavy accel.
08-22-2019, 04:41 PM | #13 |
Drives: 2018 SS 1LE Join Date: Sep 2018
I've experienced this. The shifter seems to be in 2nd gear. giving it gas and no go, as if it's in neutral. Leaving the shifter where it is long enough and not touch it, the gear(or synchros?) grinds. Even pushing clutch pedal down and pushing the shifter more into 2nd causes it to grind. I'd have to go into neutral and shift back into 2nd gear.
What I do now is firmly shift into 2nd. Baby-ing seems to increase the chance of it happening. |
08-22-2019, 08:36 PM | #14 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
It was notchy for me too going into second gear.
I noticed if I double clutch it would be smooth, and then I changed the fluid to Amsoil, and it has stayed smooth without double clutching. If it's not the skip shift, and you changed your fluid, then I would ask the Service Foreman to take a ride with you and let him see what you're talking about, then have him/her drive to see if it is replicated.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
