08-07-2019, 04:50 PM | #1 |
Drives: A Sneaky Fast Camaro Join Date: Jun 2019
Tire pressure monitor
Anyone know if you can turn it off completely?
08-07-2019, 10:52 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
No you cant.
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
08-08-2019, 08:18 AM | #3 |
THose tire sensors are annoying. Two of mine had the battery die. My mechanic told me they usually need replacement after 5 years. I didn't want to pay for him to change them while having suspension work done, so I will wait until those particular tires need to be replaced. My 'check tires' light comes on every time I sart the car.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
08-08-2019, 08:20 AM | #4 |
Guess its time to pull the cluster and block off that light.
08-08-2019, 01:25 PM | #5 | |
Drives: Miss Con Ception Join Date: Aug 2016
After 2011 all the TPMS are mandated to use 10-year batteries, so you've got that going for you. All 4 of my 2011s are still working, so they must have been anticipating the change.
2011 1SS/RS LS3 CGM
08-08-2019, 01:59 PM | #6 |
I have 1 sensor that reads low until you drive then it registers correct. So every time you start the car the light flashes.
08-08-2019, 04:14 PM | #7 |
376 cubic inches of fun
TPMS is designed to save your life. Modern tires don't look flat even at pressures that can result in catastrophic failure due to overheating at highway speeds.
I can't think of any reason to disable TPMS. |
08-08-2019, 08:15 PM | #8 |
Drives: 2013 Camaro SS Join Date: Oct 2016
Why do you want to disable it?
08-09-2019, 09:21 AM | #9 |
Drives: 2011 2SS Whipplecharged LS3 Join Date: Aug 2015
Because if you are running any tires that need lower pressures like drag radials, they are annoying.
08-09-2019, 09:33 AM | #10 |
There is a way around this. You can find a diy online. You build a pvc container and install a valve on it. You place your 4 tpms sensors in it and seal it up. Fill it to 35psi and the set it in your trunk. Done.
2014 2SS/RS LS3/M6
08-09-2019, 10:29 AM | #11 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
Have you tried having them reset at a tire place?
Levon H. Bone Stock |
10-17-2019, 10:40 AM | #12 |
pnwdan, you sir, are a genius. I have been swapping my drag tires/wheels out to get used to driving with them, and the warning light has been driving me nuts. Many thanks!
10-17-2019, 12:34 PM | #13 | |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Friend just lost a single sensor in his 2014 Shelby, took it to Ford where he paid about $150.00! I recently had one OEM sensor go out on my original factory 20" wheels, there was no need to remove the tire from the wheel then rebalance. Break the one side down to gain access to the TPMS sensor, remove the bad, install the new and add air! I figured if one went the others probably are not that far behind so I changed all four. With the Autel TS601 I am able to program all 4 TPMS sensors at one time and actually program them for position on the vehicle. Had one local Marine who thought his information center was going screwy because he would get an occasional warning light. I checked his car with my the TS601 and it showed the battery as OK, checked it a second time and it was faulty. We changed the original sensor and his problem went away. Not sure if it's true or not but I have heard scuttlebutt that the new TPMS sensors have batteries that can last up to 10 years? I wouldn't think this applies to those made in second or third world countries. I am sure the industry could make a TPMS sensor that we would be able to change batteries like in our watches or hearing aids. Of course the industry and many might lose a dollar or two.
10-17-2019, 03:34 PM | #14 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Exactly... I have TPMS for over 10 years and still work. In the summer, I bought new tires, so I bought a new HUF TPMS with a 10-year battery. 5 years ... This is I listen first time |
