06-16-2019, 07:18 AM | #1 |
Drives: '14 2SS/RS 1LE NPP, NAV, Recaros Join Date: Apr 2014
Exhaust Upgrades w/ NPP?
Looking to start the mod journey on my DD 1LE. Have a CAI, and looking for a bit more HP on a budget, and thought exhaust mods might be next. Not looking for obnoxious levels of noise, need to pass emissions, and I do like the NPP on my car.
Any recommendations? LT Headers, Hi-Flow Cats, X-Pipe? Thanks!
If You're Not Having Fun, You're Not Doing It Right
06-16-2019, 07:48 AM | #2 |
Drives: 14 Camaro 1SS RS 1LE Summit White Join Date: Jul 2014
I would leave the NPP. Do the LT's and X-pipe.
2014 1SS/RS 1LE, Summit White
2000 Trans Am 2004 LWB Chevy 2500 Van |
06-16-2019, 08:14 AM | #3 |
Go Long tube headers w/ cat deletes and a remote tune would work great for you. I had my 1LE with this exhaust setup w/ NPP for 3 years. Excellent set up.
Car mods: never enough!
06-16-2019, 08:25 AM | #4 |
Drives: 13 IOM 2ss RS manual Join Date: Jun 2018
I put on LT’s and 3”, no cats, X pipe, all from LG motorsports, I connected to my factory NPP mufflers. I still have the fuse in, so the NPP is still active and functional. The sound is exactly what I was looking for, slightly deeper under normal driving, then when I go WOT it gets aggressive and considerably louder.
Rectangular Dollars will beat Cubic Inches
06-16-2019, 08:29 AM | #5 |
He has to pass emissions so cats are a requirement.
I have long tubes with a 2 3/4 Z28 system they don't have resonators in them with a X Pipe from a C7 corvette (corvette forum about 50 bucks and it looks factory). High flow cats and the NPP on my 2010 SS sounds amazing. Also have the Z28 CAI. PM me your number an Ill send you a sound clip from NCM.
Orange Krush II
06-16-2019, 08:38 AM | #6 | |
06-16-2019, 09:15 AM | #7 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Another vote for LT's and a tune. RDP has a great deal on both as a package with lifetime tunes. You can expect at least a 50+ rwhp gain from those mods (including your CAI).
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
06-16-2019, 09:22 AM | #8 | |
Drives: 2014 2SS/RS Join Date: Jan 2018
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
06-16-2019, 10:01 AM | #9 |
Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
+1
Kooks LT’s with catted connection pipes Cut H pipe out and add X pipe https://www.amazon.com/Exhaust-Diame...s%2C152&sr=8-3
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
06-16-2019, 10:50 AM | #10 |
Started#gottalovethatblue
Keep the NPP and get some long tube headers with high flow cats and a quality tune. You should pass inspections no problems and you'll love your new found sound and power.
06-16-2019, 01:30 PM | #11 |
Whatever you decide to do. I'd get a tune to optimize the combination. Even if it means buying cheaper headers. I have Speed Engineering on mine and had them on the car for about 85k miles. They owe me nothing at this point. No leaks, no retighting, no gasket blowouts. I'm at 3 cams and 2 set of heads at 119k and the headers were the most cost effective mod I made.
06-16-2019, 01:44 PM | #12 |
Drives: 2015 1LE Join Date: Oct 2015
Headers with NPP is perfect sound level. Comfortable when cruising and loud when you punch it.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
06-16-2019, 02:47 PM | #13 |
Drives: 2011 2SS/RS Join Date: Feb 2016
Longtubes, xpipe, NPP. Fantastic with stock internals ora cam. Makes me wonder why people delete it.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
06-16-2019, 09:03 PM | #14 | |
Drives: 2014 1SS/RS, LS3, NPP Join Date: Feb 2019
Your response above is kind of what I was thinking for my eventual exhaust mods: LTs, high flow cats, NPP, and a tune with a DIY 3 way switch for ultimate control. (No emissions testing in FL but don’t want the strange smell from cat delete.) |
