04-27-2019, 02:51 AM | #1 |
Drives: 2017 2SS M6 Join Date: Jun 2013
GM no longer offers the ZL1 1LE aluminum bushings as a kit
gm has in fact discontinued there 84341929 rear zl1/1le bushings. the only way to purchase them is with a rear cradle.
04-27-2019, 06:33 AM | #2 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
Guess you could call around and see if anyone still has them sitting on the shelf?
04-27-2019, 10:37 AM | #3 |
Drives: gas powered Join Date: Jan 2019
Have a machine shop copy them.
04-27-2019, 01:07 PM | #4 |
if i had the blueprints. my sisters boyfriend is a machinist. he runs a lathe
04-27-2019, 01:08 PM | #5 |
wildhammer already did.
04-27-2019, 01:31 PM | #6 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I am not sure that is a bad thing actually (with the exception of initial cost).
Having gone thru the process, it's a pretty intensive process, which usually requires heating up the rear cradle (potentially weakening the metal chemistry) My performance shop opted for the more labor intensive route of sawing the rubber bushings out, rather than heating up the cradle. I was totally ok with that. As a secondary reason, GM probably also wanted to make the price of entry steeper to protect the handling benefits of the ZL1 1LE. While the DSSV's are more track focused, the biggest upgrade to the stability and handling between the ZL1 1LE and the ZL1/SS 1LE are those solid rear cradle bushings.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
02-16-2020, 03:57 PM | #7 |
looks like these are back in stock at https://www.gmperformancemotor.com/P..._Code=84341929 I just sent them a message to conferm and waiting for them to get back to me. 1 Member here said he ordered and they were shipped.
02-16-2020, 04:00 PM | #8 | ||
02-16-2020, 07:47 PM | #9 |
That's was awesome. Wish that video was around when I had mine done.
Current:
02-17-2020, 05:29 AM | #10 |
https://www.gmperformancemotor.com/parts/84341929.html
https://www.gmpartsgiant.com/parts/g...-84341929.html https://paceperformance.com/i-238753...-f-cradle.html https://wildhammermotorsports.com/16...t-performance/
Orange Krush II
02-17-2020, 10:17 AM | #11 |
Drives: 2017 SS 1LE Join Date: May 2018
I got my shipment in last week. They will go on sometime in spring. I purchased from the link below.
https://www.gmperformancemotor.com/parts/84341929.html |
02-17-2020, 02:12 PM | #12 | |
pace says no shipping available for my address and wont let me do anything but complete transaction. wildhammer still says out of stock.
02-17-2020, 03:09 PM | #13 | |
Drives: 2017 HBM SS 1LE Join Date: Dec 2016
Update: And arrived! Last edited by Wolff; 02-18-2020 at 08:14 PM. Reason: Update |
02-17-2020, 03:11 PM | #14 |
yep just got my shipping notification too
