dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 04-11-2019, 11:18 PM   #1
leemozoid
leemozoid's Avatar
Drives: '15 Silverado LTZ & '13 ZL1 ragtop
Best launch pressure for NT05R?
What's the safest lowest psi anyone here has used on a non-bead locked rim? I plan on launching in 2nd gear with the nannies off with a 2 step. Currently about 700 rwhp and 3600 rpm stall.
leemozoid is offline   Reply With Quote
Old 04-12-2019, 12:19 AM   #2
dru21281
You can try as low as 18-22psi. If the tires are low profile don't go too low., what size are they? Start around 26psi hot and drop 2-4 psi each time and try again.
Sent from my Pixel 2 XL using Tapatalk
dru21281 is offline   Reply With Quote
Old 04-12-2019, 06:41 AM   #3
leemozoid
leemozoid's Avatar
The 18" profile equivalent of the OEM 20" tire.
Old 04-12-2019, 07:39 AM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I hit my 305/45/18 NT05R's at 18psi and they seem to like it there. I'm not sure they will tolerate much lower.
Old 04-27-2019, 08:55 AM   #5
sulrich
Steve
sulrich's Avatar
Drives: 2014 ZL1 Vert Red & 2012 ZL1 Black
I've been running 17 PSI in the Nitto NT05R drag radial 315/35R20 tires. It did 11.859 seconds at 120.08 MPH and several 11.9 runs in my manual ZL1 with 644 rwhp. The car does 11.407 at 122.6 MPH with Hoosier Drag Slicks 28x10-17 D06 at 15 PSI.
sulrich is offline   Reply With Quote
Old 04-27-2019, 10:58 AM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
I had 305/45/18 NT05R for a while and found 18 psi was my sweet spot.
Do yourself a favor and get a set of 17s.
Old 04-27-2019, 11:07 AM   #7
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I thought 17's required a lot of work on the rear to fit.
JB'sZL1 is offline   Reply With Quote
Old 04-27-2019, 01:56 PM   #8
Vegas Bound
If zip tying the e-brake cable back is a lot of work, then yes it takes a lot of work.
