03-09-2019, 09:38 AM | #1 |
Drives: 2015 Supercharged Camaro 1LE Join Date: Mar 2018
Oil Pump Question
I have the car tore down for a cam upgrade and wondering if I should change the oil pump since I am right there now, looks like the Melling 10296 is a good choice but I cant find any selection of shim kits as I will have to take the pump apart to get it in so I will have to shim it correct ?
I can only work on the car on weekends so it will add another week to the project but from what I have read here it seems like thats the time to do it. The car currently idled just under 30 psi with stock pump so I cant really say it was giving me issues but I also read these pumps are prone to failure and I actually spoke to a guy last night whose pump failed 2 weeks after his cam install Really need help on deciding which way to go and where to find the shim kits Thanks
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
03-09-2019, 09:48 AM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
If it aint broke dont fix it, shouldn't need a shim kit i never have
Sent from my SM-N950U using Tapatalk |
03-09-2019, 11:03 AM | #3 |
Drives: 14 and 15 SS's Join Date: Feb 2018
Shim kit not needed... If you want you can take the front of the melling pump off and use felt gauges to center the drive gears, some refer to this as shimming it.
Replacing the pump is a good amount of extra work but I recommend it. If you replace the pump, you should do the chain also
Bolt-ons!
03-09-2019, 12:03 PM | #4 |
i would shim it for sure. i bought several feeler gauges to get the sizes i needed. you can cut the feeler gauge in half so you have two the same size. but dont put the cut side in first when measuring. due to sharp edge. i ended up dropping my pan and removed the pickup tube to insure perfect alignment. my pickup tube was putting to much force on the pump when in place and measuring. i would do the chain too. and Ls2 tensioner. mellings will give two choices on pumps depending on milage and mods. i went with the gm HD chain , if i did it again i would go with cr5 chain. the HD gm chain seemed to loose. I did here but dont know how true the cr5 chain was tighter. you want to be careful with not bending the pickup tube or miss aligned o-ring or damage o-ring. otherwise you will have oil pressure problems.
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
03-09-2019, 12:11 PM | #5 |
Drives: 2015 1LE Join Date: Oct 2015
C5R chain is loose too, they all are on these engines. I just grabbed 3 sets of feeler gauges from Harbor Freight and shimmed the pump gears, its easy to do. I used a 10295 standard volume/high pressure pump. My opinion is that the extra volume of a 10296 pump is not needed.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
03-09-2019, 05:00 PM | #6 |
Ok cool Thanks for the info
03-09-2019, 08:34 PM | #7 |
https://youtu.be/TsC2EtNOOPE
This will give you a step by step on the procedure
Bolt-ons!
